97 12.7 idle issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OhioHotshot, Dec 9, 2019.
  1. OhioHotshot
    OhioHotshot Light Load Member
    83
    17
    Oct 21, 2012
    Cleveland,Ohio
    Hello guys
    I'm having a issue with my ddec 4 I have repeated engine codes going on. Here's what's happening the truck idles rough up to about 1k rpm in park position runs fine going down the road. My mehanic at the terminal is saying it's a optimized idle issue from the the ecm, but the kicker my truck doesn't have that feature. So before I shell out for a new ecm, could this possible be a swapped ecm that's causing this issue?
    Thanks in advance for your help
  3. jamespmack
    216,477
    Start with frame to block ground wires. That is normally what I have seen.
    Simple, clean a spot on frame and block. Clamp on a jumper cable and set if it smooths out. Had one that loped like a 2 stroke and changed rpm with blower motor switch. Someone left the ground loose on the block.
    Or does it still have a APADs controller for A/C system? If so unplug it once and see what happens.
    OhioHotshot Thanks this.
  4. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    Does it stop doing it when you release the parking brake?
    AModelCat and OhioHotshot Thank this.
  5. OhioHotshot
    83
    17
    Oct 21, 2012
    Cleveland,Ohio
    Where is that APADs located I'll check that later tonight.. Thanks for your input..
  6. OhioHotshot
    83
    17
    Oct 21, 2012
    Cleveland,Ohio
    No sir still does it. With brakes released
  7. jamespmack
    216,477
    What year and model? I just recall some 2000/1999's Centurys having them above the right front steer wheel. When they crapped out, it logged all kinds of false codes and non existing codes in ECU.
  8. OhioHotshot
    83
    17
    Oct 21, 2012
    Cleveland,Ohio
    I stopped a tried the brake release and here's what happened. After releasing the brake the rough idle stopped then came back on a softer rough idle and its was sporadically versus continuous.. So whatever your thinking might help... Thanks
  9. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Have "half engine mode" turned off in your ECM. You will need DDDL 6.45 on laptop to do that.
  10. benjamin260_6
    433
    484
    Aug 8, 2012
    Ontario, Canada
    As QUALITYTRUCK mentioned, I was thinking the half engine mode might be turned on. It can be set to come on without the parking brake but that's rare. If you turn it off, depending on which engine model it is, it might smoke a lot when it's cold
  11. OhioHotshot
    83
    17
    Oct 21, 2012
    Cleveland,Ohio
    It's a 1998 century 12.7
