99 freightliner problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by City-Boy, Feb 18, 2025.
  1. City-Boy
    City-Boy Light Load Member
    101
    110
    May 20, 2017
    Deep south BAMA
    Hoping someone can help me out I'm on day two out of service. Started my truck Sunday Night ran for 30 or 40 minutes while I'm getting things around jumped in the truck and air buzzer was still on sitting around 20 psi. I knew my compressor was old so I changed the compressor and Governor today started the truck psi still sitting at 30 ish!! Crawled under the truck and air is blowing out of the bottom of the dryer not the relief valve but the purge. My son started pulling on the tank drains the first closest to the motor was pouring water the larger one behind that was pouring a muddy looking mess of water and oil. Drained those out until nothing could be seen coming out but air still not building and still coming out of the dryer!! When I would push up on the purge area air would slowly start building but not enough to make it purge. Any ideas? I'm already grand into this and two days down I really don't want to keep throwing parts at it. I'm already thinking (besides the oil in the tank) that my compressor wasn't the main issue. The other air Guage on the dash trailer or secondary whatever it's called was riding around 100 not losing or gaining. 12.7 Detroit engine incase that helps
  3. AModelCat
    164,290
    Sounds to me like the purge valve is sticking.
  4. City-Boy
    101
    110
    May 20, 2017
    Deep south BAMA
    I wondered the same thing. I had one years and years ago strapped a belt with a quarter ran it till it popped and never had an issue again with it. I should add that before this while driving that thing would purge every 30 seconds not while sitting just driving
    Rideandrepair Thanks this.
  5. City-Boy
    101
    110
    May 20, 2017
    Deep south BAMA
    Would stuck purge valve cause the water build up in the wet tank
  6. MRMTRANS
    MRMTRANS Medium Load Member
    407
    440
    Apr 28, 2015
    I'd at minimum replace the purge valve. I personally like to change the whole drier. $15-$200 more, but you save an hour or so of time and there can be pitting from corrosion on the drier by the O-rings between it and the valve. Might not leak air there now, but maybe soon enough that you'd wished you'd bought a new drier. Coincidentally, AD-9 driers and valves are on sale at Freightliner in Omaha. $239/$73 drier/valve for my truck. So maybe other dealers have them on sale.
  7. Big Road Skateboard
    7,055
    39,949
    May 2, 2021
    A dryer that has no more capacity will.
    @AModelCat @MRMTRANS have you straightened out.
    Replace the whole thing and be done
  8. DUNE-T
    DUNE-T Road Train Member
    7,039
    17,145
    May 10, 2015
    Detroit, MI
    I had a similar problem. There is a hose that goes from air dryer to the first air tank and there is a valve there attached to the tank where hose connects. Clean or replace that valve, if you don't have it, see if tank hole is not plugged with ice
  9. City-Boy
    101
    110
    May 20, 2017
    Deep south BAMA
    I'm in the south so right now ice isn't an issue.
  10. City-Boy
    101
    110
    May 20, 2017
    Deep south BAMA
    Isn't the purge valve located on the dryer? I'm just trying to learn as I go here
  11. Big Road Skateboard
    7,055
    39,949
    May 2, 2021
    Yes
    Oxbow Thanks this.
