A\C CLUTCH NOT WORKING
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Beto0, Jul 20, 2018.
  1. Beto0
    Beto0 Bobtail Member
    4
    new compresor,change the a\c control ,body control , low and high pressure sensors,the one inside the evaporater
  3. Beto0
    4
  4. truckmasters503
    truckmasters503 Bobtail Member
    What’s the voltage going to the compressor? With key on engine off, a/c on max? What are your low and high side pressures? Do you have power (12volts)going to high/low pressure switch? Is the connector going to high/low switch terminals spread, or pushed back?
  5. Beto0
    4
    no voltage in the compresor no voltage in pressure switch it has good pressure . there's a cable A77 if I bypass and put voltage the compressor works
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Are you asking for help, or is this a contest to see who can guess what you're working on?
    I guess an International (based off a fussy close up pic). Do I win?
    Heavyd, SAR, AModelCat and 1 other person Thank this.
  7. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    It's a Prostar. He already messaged me.
    SAR Thanks this.
