A/c drain hose
Discussion in 'Freightliner Forum' started by zx14rider, Jun 17, 2018.
  1. zx14rider
    zx14rider Bobtail Member
    16
    Oct 8, 2015
    MS
    I have a 2012 cascadia thats leaking water on the passenger floor. Where is the drain plug located so I can clean it
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    the a/c box is located outside of cab.
    zx14rider Thanks this.
  4. marpolsdofer
    marpolsdofer Light Load Member
    106
    31
    Apr 7, 2015
    On my Sterling the box that houses the evaparator does not have a hose. Just has a slight increase with a small rectangular hole at the bottom center. I thought it was odd at first.
  5. Ic3man83
    Ic3man83 Bobtail Member
    Mar 31, 2019
    Hey I'm having the same issue with my 2012 Cascadia. Where exactly was the drain hose located?
    Bennyjo Thanks this.
  6. Ic3man83
    Mar 31, 2019
    Hey, I have the same issue with my 2012 Cascadia. How did you fix the problem?
  7. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    The drain is probably (I’m familiar with the Coronado) located just inside of your right side cab mount.
    More than likely your evaporator is plugged if the drain has plugged. Once you get the drain flowing, pull your lower right kick panel, remove the fan (you’ll just see the inside air filter you didn’t know about) reach in a wash it out.
    I’ve got a garden hose fitting with a 1/4 turn valve bushed down to @ 3ft of 1/4” air line I built to reach in there. Use your phone to reach in and take a picture now and then so you can see what spots still need rinsed. You’ll probably notice a big difference in the air flow out of the vents.
    Rideandrepair Thanks this.
  8. Bennyjo
    Bennyjo Bobtail Member
    Aug 25, 2019
  9. Bennyjo
    Aug 25, 2019
    shawn9831 Thanks this.
  10. Bennyjo
    Aug 25, 2019
