1. Bernard D
    Bernard D Heavy Haul Member
    104
    27
    Jun 27, 2020
    A/C only works with engine fan toggle switch on at dash only.
    Replaced 2 sensors that i know of, Hi. and Lo. Sencors.
    ?? Any help would be great thanks.
    2003 PETERBILT 379... C-15
    OLD WERNER TRUCK CONVENTIONAL.
    Reason for edit: Spelling
  3. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    When you say it only works with the manual fan on. Do you mean the compressor only activates with the switch or is only cold with the fan on?
    God prefers Diesels Thanks this.
  4. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    To add to what @bad-luck said -
    Did you recently buy the truck? If so, the previous owner might have wired it up like that so when you're idling you get enough air across the condenser. Does the A/C work when you're moving, with the fan switch off, or does it only work when the fan switch is on. And what I mean is, will the compressor clutch only engage when the switch is flipped, or will it engage without it, but just blow warm air?
    bad-luck Thanks this.
  5. Bernard D
    104
    27
    Jun 27, 2020
    Good question ,i will have to check that out .
    Ill get back thanks
  6. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Your welcome
  7. Bernard D
    104
    27
    Jun 27, 2020
    Switch in cab engages compresor.
    Now im not getting cool air just warm air with engine fan engaged.
    Should i look at sensors again.
  8. Bernard D
    104
    27
    Jun 27, 2020
    I had a shop recharge unit about 3 months ago no leaks then idk?
  9. Bernard D
    104
    27
    Jun 27, 2020
  10. Bernard D
    104
    27
    Jun 27, 2020
    AC started working on its own.
    So this means that the problem coud lie in the sensors?
  11. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    It's hard to say, thinking it's an electrical problem. Wire, ac relay maybe. It's really difficult to diagnose an issue on a forum
