1. Bernard D
    Bernard D Heavy Haul Member
    104
    27
    Jun 27, 2020
    2003 peterbilt 379 C15 cat. Ac only works when i use toggle switch to engage fan clutch.
    Clutch is not enguaging at idle or getting loaded or moving slow
    Replaced hi and low censors.
    Any ideas welcome before i take it in and pay alot for somthing i can do myself.
    Truck on have,a vreat day.
  3. Concorde
    Concorde Road Train Member
    5,387
    18,908
    Jun 29, 2016
    West Melbourne Florida
    Mine acted almost the same as yours..Freon was low.
    That’s where I’d start. Have the system evacuated weighed and filled.
  4. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    How old are the condersor,ac radiator and the lines.?
    Rideandrepair Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,539
    6,612
    Aug 26, 2014
    If it is low maybe just add a little freon. Anyway find a good A/C tech.
  6. Bigtruckdrivah
    Bigtruckdrivah Light Load Member
    186
    224
    May 31, 2020
    Sounds low on Freon. Put some gauges on it and see where it’s at
  7. SSDD
    SSDD Bobtail Member
    Jul 30, 2020
    Without hooking up gauges to it for a more accurate diagnosis , I would check how dirty that condenser is . Sometimes you get a bunch of bugs and dust on the fins and if this is only happening during idle it could be indicative of a filthy condenser. If dirty try to hose it down from the radiator side only otherwise you will be pushing debris into the rad . Depending on arrangement condenser is usually held together by minimal amount of screws .
  8. Rideandrepair
    17,502
    56,737
    Aug 8, 2015
    X 2, best to take it off, leave lines connected. Chances are the front of the radiator is blocked with crud. They sell coil cleaner, But some are acid based. Brake clean works good. Power washing can bend the fins. If the radiator fins are very plugged up, take the grill out, and clear the crud carefully with a small screwdriver, trying not to damage the fins. You can also get a fin comb, to straighten them, inexpensive. An easy diagnosis is to put a house fan in front of condensor, but you already know air works while driving. You can cool the condenser down with a water hose at idle, A/C should work. That tells you the air flow is blocked.
