a few tricks I have learned..
Discussion in 'Experienced Truckers' Advice' started by telcobilly, Apr 5, 2010.
  1. telcobilly
    telcobilly Medium Load Member
    614
    163
    Sep 30, 2008
    Laying Low
    I'm by no means an experienced trucker but I have learned a few tricks for the newer drivers. When I measure the trailer for the 40' kingpin setting, I step off 10' from the back, instead of measuring 40' from the front. After I step off how much I have to slide the tandems, I step off the same amount from my driver side step and set a glove on the ground, I then back the edge of the step to be even with the glove and I'm golden.
    Also, at docks where the tandems are required to be slid all the way back, I will release them first and only slide them after I'm completely lined up, much easier.
    Finally, I have learned so much from just watching experienced drivers backing at truckstops and docks and try to duplicate what they do.
  3. Scuby
    Scuby Heavy Load Member
    816
    235
    Mar 10, 2007
    Telcobilly a tape measure and duct tape works better on measuring bridge laws. BTW if you can have the shipper load trlr for Calif. for every load if you can. The reason being is if you are legal for Calif. your legal in the rest of the states. If you get to the point where you think you know everything about trucking quit driving. This attuide makes you dangerous.
  4. Diesel Dave
    9,635
    32,546
    Jan 20, 2010
    Hesperia, Ca.
    :biggrin_2559:Telcobilly, you got to be kidding, right ? ILMAO
  5. ihford350
    ihford350 <strong>The Grease Monkey</strong>
    80
    47
    Jan 12, 2010
    Juneau, Wi
    Not that it matters for everyone else, but my company puts on red marks on the frame rail on the trailer that you line the mudflap up with and thats the legal mark.
  6. Elvenhome21
    Elvenhome21 Heavy Load Member
    735
    240
    Nov 17, 2008
    Sheboygan, WI
    go off of # of holes in the slider. it works so much easier. if your company uses all wabash trailers or the same brand the holes dont change.
    NON air ride is 4in spacing, AIR RIDE is 6in spacing so count accordingly. like a schneider wabash counting all holes from the front to the tandem pins minus the one where the crossbar is, thats your number. If you look at a newer schnieder trailer like TA700000 and up they have a yellow sticker above the tandews with a chart that says what holes for what states. If i get one of those trailers ill post a pic to show.
    example. cali is 5th hole or forward. so you have the starting hole way in the front which im using a 0 then you get the crossbar which is x then you get the tandem pin thats the is t.
    so its oXoooToooooTooo the front pin is in the 5th hole. on some trailers you will have 2 open holes then the crossbar, the same counting applies. ooXooToooTo pin is also in 5th hole
    michigan is 4 thru 14 but anything you haul should be ahead of 13th hole even for pallets.
    Michelangelo and JustSonny Thank this.
  7. Saddle Tramp
    Saddle Tramp Medium Load Member
    590
    235
    Jul 13, 2009
    laurel, nebraska
    Heyl truck lines have bridge settings on the side of their trailers for some of the states & canada that they drive through.
  8. Scuby
    816
    235
    Mar 10, 2007
    Thats what Duct tape is for. Pull about 6 inches and hang it at the marking. I was taught this and it works great for a solo driver.
  9. telcobilly
    614
    163
    Sep 30, 2008
    Laying Low
    ??? what's your point? I tried to pass on a few tricks that I found useful and I certainly didn't try to pass myself off as an experienced driver.
    Funny how others laugh at people trying to help...
    end of the road and gdyupgal Thank this.
  10. Diesel Dave
    9,635
    32,546
    Jan 20, 2010
    Hesperia, Ca.
    Didn't mean anything bad by it. I just never heard of that being done. If it works for you, more power to you. Since you posted this thread I've read a few and puzzles me the way drivers get it done. Im old school and usually don't go where king pin settings have to be adjusted. I pull either a spread or fixed tandems and loaded right the first time.
  11. doubledragon5
    doubledragon5 Road Train Member
    2,935
    4,088
    Jun 8, 2008
    Lewisville TX
    Wrong move there, if you watch to many Swift's, Werner's you might end up backing off a cliff, and never know it until it is to late LOL..
