A newbie asked me, TOOLS ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lonegreeneagle, Nov 17, 2011.
  1. lonegreeneagle
    lonegreeneagle Bobtail Member
    Behind my sleeper is a 9 drawer Craftsman tool chest, From a full set of 1/2" drive sockets 6pt. and quite a few 3/4" drive sockets, breaker bars w/ cheater pipes, ratchetts, box/open end wrenches, wire cutter/strippers, tin snips&gloves, multi-meter, crescent wrenches, screwdrivers, (now Torx) drivers, BIG hammer, winch bar, WD-40, electric&duct tape, 12ton bottle jack, torque wrench and insomnia......
    The best tool I could give him; ask your employer what you are allowed to do? What they say you should have? How experienced he is at wrenching dictates what he can work on, repair or fix himself to get back on the road. The best tool for me, was a pair of vice-grips when I first started driving. I couldn't afford much else!
    What is the current company policy? O/O's hiring occasional drivers, what do you require?
  3. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    I used to carry a tool set like that with me, but the handtools were constantly being damaged by vibration. Ratchets, torque wrenches, crescent wrenches, geared tools, pulley pullers, snap ring pliers and tools with moving parts in them. Are you having a similar problem?
  4. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Who remembers stories about guys doing an inframe on the side of the road? That would likely take a bit of tools. Lol.
  5. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    I took a 3 pound hammer with me. Some good crescent wrenches. Two sets of combination wrenches 3/8-1.5". Tire irons (would have been nice to have an air canon). One of those megawatt hand held flashlights with tether cord. Air hose with tire chuck, tire pressure air guage 50-130 range, as well as blow gun, and a air grinder. A couple of cans of elephant snot (lubricant). A cordless drill, as well as a 130 piece drill box (has everything you would ever need). A hex drive screw driver handle (when the cordless dies or is charging).
    Anything more than that I might as well be at home with the lathe and mill.
  6. lonegreeneagle
    The new tool box of dreams is the Montezuma! Guaranteed by design to not let tools slip their position?!?!?!! I have 1.5" foam over my tools in the drawers now.
    Road side repairs from my past; broken U-joint, crushed air lines, frozen brakes, dried/killed turbo!, and of course tires.
    Draw back to the Montezuma- no room for large sockets or wrenches, nor a drawer beneath for king pin hook, cheater bar, or winch bar! With 34" frame to frame outer I like a 36" wide tool box. Benefits are; angled lid to stop tool movement and let rain and snow slide off, dry seal and weight! Anyone that can run away with my tool box can have it! Now if you load it on a truck/pick-up, I'll hunt you down.
    As for drills, I recently bought a Bosch 18V mini 3/8" drill and impacter. The impacter with a 1/2" socket extension starts and seats most nuts and bolts effortlessly! The undermounted lite is great when your underneath or in the dark.
    "WRENCH IT YOURSELF, CUT YOUR DOWNTIME!"
    Van/LGE
  7. flightwatch
    flightwatch Road Train Member
    1,249
    1,251
    Jun 22, 2011
    Somewhere in Texas
    If I can't fix it with a Leatherman, the truck will go to the shop since it's under warranty.
  8. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Ditto on the Vice Grips. Alligator jaws can be used to pinch of broken airlines and limp an otherwise disabled brake system to a shop.
    Diesel Dave Thanks this.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    add simple J1708 scanner, DVOM, heat shrink kit, and wire cutters, LED puls probe, o-scope, CAN viewer, laptop, RP1210 adapter..... especially if you have new truck aka volvo, KW, Peter, MAN, ore Actros))))
  10. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    I see a lot of useless things being carried around for no reason other to impress some newbie. After being out here as a O/O for 16 yrs.
    All one needs is a full set of wrenches, 1/2 & 3/8 deep sockets & extentions.
    You'll find 9/16, 5/8 and 3/4" is your most popular sizes needed.
    Hammer, 4 screw drivers 2 small & 2 Larger phillips and straight head, allen wrench cluster. 1 med crescent wrench
    vise grips and a 18" pry bar or breaker bar, preferably.
    A Hack saw does come in handy, but not very often, but its nice to have.
    Air line, air chuck and air gauge and maybe air ratchet.
    Electrical, small fishing tackle box works great, assorted connectors, butt connectors, splicers, shrink tubing, fuses, 12V tester, pigtail tester, electrical tape, Ohm meter is also helpful. extra lights... ZIP TIES !!! lots of them.
    Incidentals...
    tube of silicone gasket maker
    Teflon tape
    Never seize
    Duct tape
    plugs 1/4, 3/8 and 1/2"
    Air line splicers 3/8"
    valve stem cores
    slack adjuster pins and cotter pins
    Flashlight and a head lamp (light that clips to a hat bill or goes around your head... trust me when I say that is what you want for those late night emergency repairs.
    1 spare brake air line or one that can be made up to fit, generally a #8 hose with ends you put together yourself.
    Spare Alt belt
    spare headlight, tail light and signal light.
    (sure you can buy them at a truckstop and pay double or triple)
    a small propane torch to help with frozen brakes in winter
    Supplies...
    washer fluid
    Diesel treatment, winter time... 911 emergency melt
    Anti freeze
    1 or 2 gal of oil
    2 fuel filters and wrench (I carry small qt bottle of diesel for filter changes)
    small supply of shop rags and hand cleaner
    I also keep a box of latex or nitrile gloves to help keep the hands clean.
    I realize all this sounds like a lot, but it really isn't.
    All the tools fit in one 24" tool box and a small fishing tackle box for the electrical stuff.
    The supplies fit in a couple of milk crates.
