I was wondering the general rule for using bright lights. I have been told to use my brights whenever I safely and legally could.
without being told what that actually means.
How far away does an oncoming car have to be before its a problem for them?
How soon - or far - after someone passes me can I generally resume using my brights?
In regards to oncoming traffic, how much does the angle of where I am in relation to their position matter? Does a wider median make it possible to use brights even when the distance is being closed by oncoming traffic?
thanks for any input.
About running with brights?
Discussion in 'Experienced Truckers' Advice' started by Rebel Patriot, Feb 23, 2008.
An oncoming vehicle or vehicle in front of you must be a minimum of 600 m (2000 feet) away from you.
If you can see their headlights, I always turn off my brights. I'm super sensitive to lights so really hate people who run with their brights on, even in the daytime. Lights these days are so bright having high beams on is horrible to us who are sensitive.
I see cops and bus drivers with them on 24/7 though - sigh...
The legal distance in Canada is 600 m or 2000 feet. -
I do believe that at least in Michigan the legal limit is about 500 feet, thats what I was told when I took Drivers Ed for my regular licence a few years back when I was 16.
I practice:
If you can see the tail lights, no brights.
If you see the head lights, no brights.Semper Rotans, Chain Drive and Roadhound Thank this. -
I will second what Roadmedic said
Same here. Otherwise, light 'em if you got 'em.
I'll agree with Mack and Roadmedic on this. And I'll also add this. A divided highway divides the lanes, not the vision. If you are coming toward traffic that median strip will do very little to divert your bright lights. Of course if the lanes happen to have a two mile wide median, then that is a different story, but in most cases, if you are meeting traffic, keep the dims on.
And unless there is fog, don't use those #### fog lights, they can be as bad or worse than high beams if they are not set right! -
Yeah I just use low beams if I can see headlights coming, I never really consider how far they are away. Same with taillights.
That's what it's been on every test I ever took and I was in the military and moved alot. But it's a good practice to go to lower beams when you know for sure the high beams will not blind the driver. -
I tend to just use the low beams on the highway, I find if I run the brights it takes too long for my eyes to adjust when I meet a car and dim them
