ABS ALWAYS TURN ON
Discussion in 'Freightliner Forum' started by Nazar, Mar 21, 2018.
  1. Nazar
    Nazar Bobtail Member
    cleveland
    Good day to all. I do not know if u have already discussed this topic, but I can not find it here. I always have an ABS turn on the trailer 7 way plug even though the key is turned off. Cascadia 2012.
  3. Grumppy
    3,233
    11,401
    Dec 11, 2010
    West Monroe, La
    So, you're saying that when you connect the electrical line from the truck to the trailer, the ABS light on the trailer comes on, even if the key on the truck is turned off???
    If so, you got a short on the trailer somewhere.
  4. Nazar
    cleveland
    No ABS light at back of trailer maybe I not correct say I have always power at 7 way plug (blue wiring).Any time when I disconnect and connect plug to trailer I hear like work ABS in trailer but key stay at my hand truck not working.
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Is it causing a problem? You have constant power on the blue wire? correct?
  6. Nazar
    cleveland
    Yes u are right Sir.
  7. Animosus
    Animosus Heavy Load Member
    732
    2,905
    Dec 7, 2015
    SE Wyoming
    Get a regular 5 pin SAE relay and cut pin 87A off and you will get your intended functionality.
    QUALITYTRUCK and Nazar Thank this.
  8. NorCenArk
    NorCenArk Light Load Member
    76
    35
    Mar 31, 2011
    Russellville, AR
    Probably, the center pin was wired hot even when key is off for trailer tracking systems.
  9. Antinomian
    Antinomian Road Train Member
    2,171
    3,441
    Feb 17, 2013
    Or someone stuck the wrong relay in the socket.
