Abs code 2004 columbia
Discussion in 'Freightliner Forum' started by stlwaco, Dec 8, 2011.
  1. stlwaco
    stlwaco Light Load Member
    276
    47
    Oct 4, 2009
    St. Louis, MO
    I've been searching google all day. Popped a code today. Abs 136 sld 003 fail 08. I know the first two specify axle 2 left sensor. The fail 08 is what I need now. Just need to know what it is trying to say.
    Thanks
    Mike.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    rear axe left WSS wrong sygnal.
    What did you do with rear brakes?
  4. stlwaco
    276
    47
    Oct 4, 2009
    St. Louis, MO
    didn't do anything to the brakes. we did swap out the X1's for duals. The shop did that on Monday. A local driver drove it around till I got back from a repo on Wednesday night. He said the light came on about an hour before he turned the keys over to me.
    Today I remembered the ABS CHK button in the side door. Got the light to flash a code 11.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ok, remove brake drum, inspect wiring and WSS (usually WABCO ABS-E, made in Wrozlaw ABS Electronic Unit), change bad parts you sugest (WSS, extension wire), inspect tone ring, change if it is bent
  6. stlwaco
    276
    47
    Oct 4, 2009
    St. Louis, MO
    Shop just called. They found the tone ring had a missing tooth. Replaced it, cleared code. All seems good now.
