ABS LEAK
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LUNDRYJEFF, Aug 26, 2023.
  1. LUNDRYJEFF
    LUNDRYJEFF Bobtail Member
    19
    Aug 26, 2023
    HEY GUYS GOT A 2018 FREIGHTLINER ABS VALVE IS LEAKING IN THE CENTER WHEN PARK BRAKE IS RELEASED PINCHED OFF AIR LINE ON THE TWO PARK BRAKES AND IT STILL LEAKES REPLACED ABS VALVE AND IT STILL LEAKES
  3. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    Break chamber bleed back,
    Start pinching them off one line at a time, yes all eight
    LUNDRYJEFF and AModelCat Thank this.
  4. LUNDRYJEFF
    19
    Aug 26, 2023
    THANKES EVEN IF NOT PARK BRAKES
  5. LUNDRYJEFF
    19
    Aug 26, 2023
    PINCHED OFF ALL LINES ON TRUCK ONE AT A TIME IT NEVER STOPS LEAKING
  6. FLHT
    FLHT Road Train Member
    1,429
    2,544
    Aug 2, 2014
    brake chamber rubber got a hole in it
  7. LUNDRYJEFF
    19
    Aug 26, 2023
    HOW CAN I TELL WHICH ONE IT IS
  8. FLHT
    1,429
    2,544
    Aug 2, 2014
    get under their and put hand around can. you can feel the air
    Spring probably broke and put a hole in rubber.
    Hate to say it if one lets go the others are not far behind
    silverspur Thanks this.
  9. LUNDRYJEFF
    19
    Aug 26, 2023
    So you think to change them all
  10. LUNDRYJEFF
    19
    Aug 26, 2023
    Thanks ill check them tomorrow to late tonight
  11. FLHT
    1,429
    2,544
    Aug 2, 2014
    If your wallet is up to the task and you preform the labor.
    Beats sitting on the side of the road on a weekend after dark.
    Last ones I bought were around $70 each.
    blairandgretchen Thanks this.
