Abs light. Faking it
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Apr 29, 2020.
  1. insanityeight
    insanityeight Light Load Member
    291
    113
    Jul 26, 2013
    birmingham al
    Bout to lease on to my old company and abs trailer light just started acting up. Ill deal with it later but temporarily can i run a wire and toggle switch to cab to fake it? They jus wanna see it come on a few seconds and go out after turning switch on.
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Much easier is to fix #### light. If light not blinking at all - check central wire for +12 volts supply.
    If light blinking codes and stay on - check the code and fix the problem. How to check codes - easy Sealco Commercial Vehicle Products - ABS Blink Codes
  4. Flgtrisk
    Flgtrisk Bobtail Member
    18
    14
    Apr 23, 2020
    Tennessee
  5. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    That wont help
  6. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    Well it lights up a second and goes out when applying brakes which ive read is normal. But it stopped coming on a few seconds when switch gets turned on. This started the moment i got this new truck and hooked up to it. Never an issue with my old truck. Wonder if problem isnt on truck somewhere but its trailer abs light.
  7. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    If light is on for second every time when you apply brakes and not blinking from key on means ABS module powered from stop light circuit only. Check central wire on the pig tail cable for +12 volts. Probably truck side fuse.
  8. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    Don't disconnect or change wiring to the ABS. It's not an OOS item.
    As mentioned check the center pin in truck pigtail for power. Spread the pin with a little screwdriver to get better contact in the trailer receptacle.
  9. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    I spread the pin already but no change and cant find any fuses bad. May have to pay someone. Dont have a volt meter either. Code says right rear speed sensor out of range but doesnt indicate truck or trailer. May be sensor and it conveniently started the moment i got newer truck
    Rideandrepair Thanks this.
  10. Antinomian
    Antinomian Road Train Member
    2,171
    3,441
    Feb 17, 2013
    It is not normal. That behavior is a fail safe in case power to the center pin fails. The trailer ABS computer will power up from the hot lead to the brake lights when you step on the brakes.
    You have a blown fuse.
    titus and Rideandrepair Thank this.
  11. Antinomian
    2,171
    3,441
    Feb 17, 2013
    Say what kind of truck you have and maybe someone can direct you to the fuse.
    If it's a Cascadia look for a vertical rectangular plastic black box on the firewall under the hood on the driver's side. There are several relays and fuses in there. The fuse for the trailer pigtail center pin (the one you are looking for) is there also.
    titus Thanks this.
