ABS LIGHT POWER WIRE
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FARMBOY70, Nov 19, 2019.
  1. FARMBOY70
    FARMBOY70 Bobtail Member
    Nov 19, 2019
    I HAVE A 2006 LUFKIN DROPDECK WITH A WABCO CONTOLLER. SOME ONE HAS REMOVES THE POWER WIRE TO THE ABS LIGHT. I HAVE SEARCHED AND SEACHED TRY TO FIND WHERE THE WIRE COMES FROM WITH NO LUCK. DOES ANYONE HAVE A WIRING DIAGRAM OR CAN TELL ME WHERE IT COMES FROM.
    Rideandrepair Thanks this.
  3. xsetra
    xsetra Road Train Member
    5,190
    7,137
    Aug 21, 2011
    The abs power feed from your truck is the center blue wire in your pigtail. This should be powered up with the key on.
    The power feed to your yellow ABS light on the side of your trailer, comes from the ABS controller
    . Follow your sensor wires from your brakes to the air valve. This is your wabco controller.
    This is where your line for your abs light should be.
    Good luck
    Rideandrepair and FARMBOY70 Thank this.
  4. FARMBOY70
    Nov 19, 2019
    I have looked all over the wabco controller and the wiring harness going to it. I thought maybe a pigtail would come out of the harness somewhere but didn't find anything. I appreciate your help.
  5. xsetra
    5,190
    7,137
    Aug 21, 2011
    Who ever removed the wire to the light, probably removed the entire wire including the plug to the module.
    Search this:
    wabco trailer abs module wiring diagram
    Call a Lufkin dealer. They should be able to email you a schematic for your trailer.
    Good luck
  6. Rideandrepair
    17,529
    56,788
    Aug 8, 2015
    Abs troubleshooting.com. The website has all the wiring diagrams, Good Luck
    Tx Countryboy Thanks this.
