ABS light
Discussion in 'LTL and Local Delivery Trucking Forum' started by omaharj, Aug 2, 2023.
  1. omaharj
    omaharj Light Load Member
    149
    265
    Jun 18, 2008
    Omaha
    I drive for a regional (650 drivers) LTL. Some guys are taping over the ABS lights when they're constantly on or flashing. As I'm linehaul, sometimes they get handed off to me. I note it in the pre trip and red tag it at the home terminal. Anyone else even HEARD of people doing this? Management and dispatchers act like it's no big deal. I'm retiring in about a year or so and probably don't want to die on this hill. It just sems crazy. What do others think?
    kutscher Thanks this.
  3. tscottme
    tscottme Road Train Member
    It's an equipment violation and if DOT finds it the driver will get a PSP violation that stays on your record for 3 years.
    ABS light should come on for a few seconds and go dark if everything is working properly. Driving with a faulty ABS system is a violation. It's not a big deal to the people who won't get a violation on their record. They will happily suggest you volunteer for the violation as they go home for the night collecting a salary that doesn't vary based on DOT inspections.
    silverspur and snowlauncher Thank this.
  4. kutscher
    kutscher Bobtail Member
    40
    18
    Apr 19, 2011
    hesperia, ca
    I had this often also. The drivers before me, they cutted the "ABS light cable" to the ABS lamp. For me it is OK when they do it this way and drive self.
    But I think also when the driver droppes the trailer with out reporting this, then it is sabotage.
    M.
    tscottme Thanks this.
  5. Arctic_fox
    4,498
    25,376
    Sep 16, 2016
    Sadly drivers like to destroy equipment so they dont need to spend the time to get it fixed or because they are bored.
    One guy where my dad works was sticking a knife into the speakers on every truck he got to stop the following too close alarm as an example.
    That said eventually they will get caught.
    silverspur Thanks this.
  6. pavrom
    pavrom Road Train Member
    3,215
    7,407
    Apr 29, 2012
    NE illinois
    I have one of my trailer abs sensor needing adjustment and my light is always on ... Mechanic said its slap on the wrist... But all it takes is one good cop
  7. jmz
    jmz Road Train Member
    1,208
    2,858
    Mar 9, 2018
    Great Plains
    The ABS light staying on just means the system is working and shows there is a fault that needs to be addressed eventually. Notate it in your pre-trip and keep rolling. The geniuses who cover up the light or cut the wire are risking being cited for an inoperable required lamp.
    Cardfan89 Thanks this.
  8. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    You forgot the “NOT” before the “working”.
  9. Lazer
    Lazer Road Train Member
    1,848
    2,976
    Jan 22, 2017
    Dayton Freight?
  10. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    better than cutting wires. equal to unplugging those snap in ones.
    I would kick that behavior up the chain beyond pre/post.
    at the least it can be a safety meeting topic. oth its either an oos or fix it ticket. picking up loaded/sealed trailers or meeting a guy, what are we supposed to do? I run em if flashing . its on the company regardless. if enough get put out of service they can check inspection history, then address accordingly. this is asduming of course this is a driver bug and not a shop/company feature ....
    on arrival I always notify dispatch of any issue so it wont get reloaded until fixed.
    jmz and kutscher Thank this.
  11. mickeyrat
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    we have more drivers than that
