Ac acting weird!
Discussion in 'Ask An Owner Operator' started by Batman13, May 20, 2020.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    So i tried to look for my question/answer..on here and youtube as well...and the videos I saw..trucks around the same year..but they're setup is different underneath..and no luck!! I even tried to hold down the first 2 knobs until there supposed to blink...to reset it...but nothing!! When I drive the ac works perfect..but when I stop of slow down..the ac turns off!! What can be causing this issue? I took apart the bottom dash..saw one harness on the side of the blower (I think)..checked wires but I cant find any wires damaged or loose or disconnected...this happened once before but when it did..I just took the bottom piece off and wiggled the wires and it turned on...but now.......NOTHING! Anybody have any ideas???
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    To have any idea we need to know at least make of your truck. If you know year it will give us even more ideas.
    Batman13 Thanks this.
  4. Ridgeline
    22,717
    123,107
    Clean between and blow out the condenser, radiator and Cac
    AModelCat and frito bandito Thank this.
  5. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Take it to an AC shop. You arent qualified to fool with it.
    Roberts450 and 86scotty Thank this.
  6. frito bandito
    frito bandito Light Load Member
    124
    457
    May 31, 2019
    Just replace the compressor (which for warranty will require the condenser, drier and expansion valve to be replaced also.) A/C stuff is expensive at this time of year, so the more you can do the better. If you throw the manifold gauges on it it will probably be showing low pressure on the high side and high pressure on the low side becuase of an internal leak.
  7. frito bandito
    124
    457
    May 31, 2019
    Bah, FREE the CFCs.
    HoneyBadger67 Thanks this.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If you have a rad. fan switch turn it on when you get ready to stop, Ridgeline is right if that works, the Rad. fan will move air thru. a/c con.
  9. AModelCat
    164,494
    Start with the basics. Clean out the rad package first.
    Does the fan cycle on/off when parked? It should.
  10. AModelCat
    164,494
    No. Just no. Don't throw parts at it without troubleshooting.
  11. 86scotty
    86scotty Road Train Member
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    ...and we still don’t even know what kind of truck it is. Could be his F150.
