AC Always runs!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FitzNado, May 5, 2018.
  1. FitzNado
    FitzNado Bobtail Member
    33
    May 5, 2018
    Help! 2015 Fitz Coronado 12.7 series 60. 1.These came with a coolant shut off valve to the heater core. That is off. Seems I have no control of AC. It’s either always on or I gotta press the AC button to shut it off.
    2. Random throughout the day, or not at all, suddenly the engine temp gauge will swing wildly from very low up to 200+. High Coolant temp message appears, check engine and engine shut down come on for a few seconds, engine fan comes on and runs for 30 seconds or so. Then all goes back to normal.... WTH! . This may happen 20 times per day or not at all. Parked or running down the road.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Do you have defrost mode selected? A/C is always on in defrost mode to help dry out the air.
    Coolant sensor or circuit faulty.
    windsmith Thanks this.
  4. FitzNado
    33
    May 5, 2018
    No, no defrost on.
    I know these may or may not seem like two separate issues and maybe they are.
  5. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    Your thermostat could be sticking closed causing the random hot condition.
    Your A/C relay could be sticking causing the compressor clutch to remain engaged.
  6. Heavyd
    7,826
    6,276
    Feb 4, 2009
    For safety, I would unplug your ac compressor for now to prevent over pressure until you can get this figured out.
  7. FitzNado
    33
    May 5, 2018
  8. FitzNado
    33
    May 5, 2018
    AC relay? I’ve not heard of this device. What is it and where is it located?
  9. RET423
    432
    534
    Apr 6, 2017
    Kalifornia
    It is in one of your fuse boxes, it will be labeled A/C a big square item with 4 or 5 prongs that plugs in like a big fuse
  10. FitzNado
    33
    May 5, 2018
    Thanks 423! So would this relay also control the in cabin temperature? Right now I have the temperature control all the way over to the hot side But if I push the AC button the AC will work continually until I turned it off. It does not cycle to control the temperature and the only way I can do that is to manually Push the AC button off and on.
  11. RET423
    432
    534
    Apr 6, 2017
    Kalifornia
    Your heater should be able to over power your A/C even if the A/C clutch is staying engaged, some A/C systems are not designed to cycle on and off for temp control; they use the heater blend door to regulate the temp.
