Ac compressor pulley
Discussion in 'Experienced Truckers' Advice' started by Mattexx, Dec 9, 2019.
  1. Mattexx
    Mattexx Bobtail Member
    5
    I have a 2000 Kenworth w900 air conditioning compressor pulley squeals when I turn on heater and ac
  3. snowwy
    snowwy Road Train Member
    20,612
    13,329
    Jul 6, 2009
    Loose or worn belt.
    Pulley bearing
  4. Hyweighman
    Hyweighman Medium Load Member
    517
    659
    Dec 29, 2011
    Pensacola, FL
  5. Mattexx
    5
    Replaced ac compressor pulley but pulley stops when I turn on ac or heat I'm going to try charging freon
  6. snowwy
    20,612
    13,329
    Jul 6, 2009
    That's a bad compressor. It's locked up.
    Your compressor shouldn't come on with heat unless your using defroster.
    I'd disconnect electric plug at the compressor if need be. So you're not supplying power. Fix it when weather warns up
    BoxCarKidd Thanks this.
  7. Mattexx
    5
    Thx for insight the system has no pressure I'm going to try and charge system
  8. Mattexx
    5
    Could it being low on freon cause it to bind
  9. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    NO, it could possibly be over charged, but that would only show up after it ran a few minutes, and a hose or something would usually blow before the compressor ever locked down.
    Like said your comp. is toast, unplug it so that the defroster doesn't try to make it come on, and burn the belt off.
    pushbroom Thanks this.
  10. snowwy
    20,612
    13,329
    Jul 6, 2009
    There should be a hi pressure switch that shuts the compressor off if pressure gets to hi.
    HOWEVER, Freon contracts in the cold. So even if it was overcharged for summer. It won't be overcharged in the cold.
    Course, I have no idea if you're down by mexico or up by canada.
    But if the compressor won't spin. You're wasting your time adding freon cuz you're just going to have to pull it back out to replace the compressor.
    If the compressor isn't spinning. It isn't spinning. And the only cure. Is replacement.
    Add freon after replacement.
    AModelCat Thanks this.
  11. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    If the compressor won't spin, you might be able to get a little freon in it , but can't charge it even if you wanted to.
