Ac compressor stuck on unless unplugged
Discussion in 'Peterbilt Forum' started by OFT2024, May 20, 2024.
  1. OFT2024
    OFT2024 Bobtail Member
    17
    Apr 23, 2024
    05 379 c13
    noticed my ac wasn’t blowing good so suspected freeze up.
    was correct accumulator and lines froze (assumed evaporator as well)
    turned fan off ac switch off to thaw out yet compressor still ran which would exsplain freeze up had no blower motor running for hours yet compressor was running
    so unplugged compressor to prevent damage and clutch disengaged
    thoughts?
  3. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    High pressure switch bad or wrong one on the truck , or the same with low pressure switch.
  4. OFT2024
    17
    Apr 23, 2024
    If the low pressure and high pressure is within operating range then the compressor would run, correct? So if a switch in theory stuck open you wouldn’t know unless u check pressures?
    I tested the relay port 30 and 86 has power so it’s telling it to be on just not sure why
  5. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    I put on a high pressure switch from a friend that was for a peterbilt , which is what I own. It made my truck a/c freeze up. It can freeze up if the freon level is incorrect. A 379 takes 5lbs of freon, the only way to know how much is in the system is to have it drained and recharged.
