1. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    Fan started to fluxuate then died.
    Replaced fan.
    Replaced sensor.
    Going to replace the speed control switch pigtail/harness.(OEM) from Peterbilt.
    Is there any way to keep this harness from frieing it self and fan ect.
    Any suggestions are apreciated .
    Rideandrepair Thanks this.
  3. bjrc
    bjrc Light Load Member
    81
    97
    Sep 14, 2018
    As the fan motor wears out it pulls more amperage which is what heats up the wiring. Sometimes the replacement harness will be heavier gauge wire which will help.
  4. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    I have the same problem on my Freightliners Bunk switch. Replaced the expensive pigtail less than a year ago. The switch terminals are usually loose too, from switch getting hot. Makes it even worse it seems. I guess it’s better than a wire melting where it’s hidden. I wonder why the dash switch hasn’t ever had this problem. Both usually run all the time, till the fans go bad. I’m going to replace the end terminals only this time. Right now, I’ve got the high setting wire end clipped with an alligator clip. It’s pretty hot! Lol. I wanted to see if the heat was from an inefficient blower and not just from a bad switch. Guess I’ll be replacing the blower motor also. They’re not cheap anymore. I see some online for half or less than Dealerships. Learning as I go along.
  5. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    Good info,thabks
