Accelerator pedal question
Discussion in 'Questions From New Drivers' started by BillyBobFrank, Apr 23, 2024.
  1. BillyBobFrank
    BillyBobFrank Light Load Member
    208
    388
    Nov 7, 2022
    Not a new driver, but just trying to find a new way around my company's idle timeout. My company puts a 5 minute timer on the engine effect the temperature outside is below 91 degrees. Unfortunately the AC from the APU can't keep up with 80 degrees on a sunny day (black truck), so I was trying to find a method to keep my accelerator slightly pressed in order to prevent the engine from shutting off. Any tips for this balancing act?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,970
    19,009
    Nov 1, 2010
    Burnsville, MN
    A constant pressure won't do the trick.
    In the past I have taped a broom handle to the pedal with the other end resting between the upraised armrest and the chair.
    A little push every 4 minutes does the trick.
    BillyBobFrank Thanks this.
  4. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    All depends on the truck.
    Some you set the trailer brakes, but not the tractor brakes and then engage the cruise control and tap the + knob/button a couple times. Some trucks you need to set the truck brakes. If the truck has a pto switch (but no pto on the transmission), engage that switch and tap the ‘idle’ button if there is one.
    Try all different things.
    Some trucks you’re just schmitt out of luck.
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Either they fix/replace the apu to keep up, or find a new gig where they care about their drivers enough to have adequate ac before summer.
  6. tscottme
    tscottme Road Train Member
    Electric screwdriver with an off-center circle of plywood. As the circle rotates it presses & releases the gas pedal.
    BTW, company will still see your idle time & air temp & investigate or ask you to stop and fire you when it doesn't stop.
  7. Flat Earth Trucker
    4,313
    16,533
    Nov 19, 2018
    There are dozens of YouTube videos on how to keep a tractor running.
    austinmike Thanks this.
  8. 201
    201 Road Train Member
    12,758
    26,250
    Apr 16, 2014
    high plains colorado
    I'm constantly reminded how out of the loop I am, with all these gizmos we never had to deal with, but one thing remains universal, apparently, the office never recognizes YOUR comfort. Tell them not to have a/c or heat in the office, see how long THEY last. It was one of those things they didn't approve, but when put that way, they usually shut up about it. I don't know how you drivers put up with all the techy stuff, heck, we jammed a stick in the pedal, and out went the lights. Seeing all you folks put up with, if I was looking for a career, like I was in the 70s, I wouldn't even consider trucking today.
  9. SoulScream84
    3,457
    26,543
    Mar 21, 2020
    Now you know something to ask of your future employers during the interview.
  10. PaulMinternational
    PaulMinternational Road Train Member
    1,108
    5,831
    Aug 23, 2022
    I drained the freon or whatever it was in the office air conditioner a few years ago.
    Boss was cheep and I knew he wouldn't fix it till the dead of summer.
    Got filled with joy every warm day when I walked in and saw them sweating.
    snowlauncher, austinmike, 201 and 3 others Thank this.
  11. TripleSix
    133,240
    Winner.
    You run the miles, you deliver the loads, you rest and relax in comfort. All or nothing.
