Accelerator Position at Start Up
Discussion in 'Experienced Truckers' Advice' started by Mikesee, Jun 12, 2016.
  1. Mikesee
    Mikesee Light Load Member
    90
    51
    Oct 25, 2014
    What is your accelerator positioning procedure on start up? My manual says "Full depression" then "Hold at 1/2 position" for start up. The engine starts much faster this way than with no pressure on the accelerator. Others who start my truck, like my mechanic, don't do the procedure and the starter has to work longer to achieve start up.
  3. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    What kind of truck?
    I never press accelerator when starting.
    Last 3 trucks. 12, 13, 16 Cascadia.
  4. bigmotor1212
    bigmotor1212 Light Load Member
    256
    363
    Dec 20, 2014
    What year model truck are you dealing with? I thought the ECM controlled fuel delivery.
  5. Mikesee
    90
    51
    Oct 25, 2014
  6. bigmotor1212
    256
    363
    Dec 20, 2014
  7. David_Simpson
    David_Simpson Medium Load Member
    650
    637
    Feb 23, 2016
    do as the manual says, forget what the mechanic does.
  8. okiedokie
    okiedokie Road Train Member
    13,742
    108,573
    Jun 13, 2011
    PNWET
    Let the fuel atomizer on start up. Once started keep the rpm up a little till it smooths out. Then idle.
  9. UFO
    UFO Light Load Member
    157
    225
    Nov 22, 2006
    lebanon in
    pretty much all diesels start in the full fuel position. the governor then pushes the throttle back. this is for mechanical engines and early computer controlled engines as well.
    blairandgretchen Thanks this.
  10. rambler
    rambler Road Train Member
    1,358
    582
    Nov 5, 2007
    Whats that engine in, a small motor home or maybe a pickup truck? Mechanical pump?
  11. Mikesee
    90
    51
    Oct 25, 2014
    1997 Topkick 6500 fuel system is mechanical
