Access to timing marks
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mike(Big Irish)Porter, Apr 14, 2023.
  1. Mike(Big Irish)Porter
    Mike(Big Irish)Porter Bobtail Member
    17
    Nov 1, 2015
    On a 12.7 Detroit can you access the timing marks on ALL front gears with the front cover on. through the access covers
  3. Big Road Skateboard
    7,053
    39,945
    May 2, 2021
    No. But you can still check timing. Pull #1 injector and set at TDC with a dial indicator. Pull cam gear cover and your cam gear timing mark should be dead center in the gear mesh.
    Why do you ask? If someone is saying they need to pull cover to check, they're FOS
    Oxbow and Rideandrepair Thank this.
  4. Mike(Big Irish)Porter
    17
    Nov 1, 2015
    Thanks for responding !st the put new cam on new head and the clamed that the timing was off. then they removed the front cover they didn't explain why. I was under the impression that you could access the timing marks on the gear with the cover on .when I asked what he found when he removed the cover he couldn't or wouldnt give me a definitude answer something stinks
  5. Mike(Big Irish)Porter
    17
    Nov 1, 2015
    I have no idea what there doing ,when they removed the front cover they said everything was fine !!!!!! 23 hours to remove the cover to tell everything OK
    Rideandrepair Thanks this.
  6. Big Road Skateboard
    7,053
    39,945
    May 2, 2021
    I was curious after you mentioned tjem saying it was out in the other thread. Sounds like you got shafted. The Detroit manual has a detailed section on timing, and how to check.
    What I mentioned above is how I've done it for years.
  7. Big Road Skateboard
    7,053
    39,945
    May 2, 2021
    Why was it in the shop to begin with?
  8. Rideandrepair
    17,532
    56,814
    Aug 8, 2015
    Should have replaced bull gear and front main seal while it was apart.
  9. Mike(Big Irish)Porter
    17
    Nov 1, 2015
    what manual are you talking about and can you send me a link i have the 60 ser manuals
  10. Big Road Skateboard
    7,053
    39,945
    May 2, 2021
    I don't have access to the manual right now. Maybe google cam timing check series 60?
    Oxbow Thanks this.
