Acert c-15 need help!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 07pete379, Mar 5, 2020.
  1. 07pete379
    07pete379 Bobtail Member
    Here is the story. Had a platinum rebuild done and had to get my ECM reflashed. I had another CAT file in it, but it would void the warranty of the rebuild. After a few days of running it the truck began to run rough. I went in to the shop and the ECM showed that injector 3 and 4 had reverted back to the previous trim codes. After changing them back to what they were supposed to be the ECM would lose the codes and revert back to the old ones if the key was cycled off. Replaced the ECM and it did it again as soon as it came out of the 24 hour test mode only this time showing injector 3 and 4 not programmed because it was a new ECM. Replaced the ECM yet again and it did the same thing. Tried to clear it out and it wouldn't. Had to install a different file in it from another truck and then clear it out. Then manually put in all the information and it seems as though the problem is back. Going to the shop in the morning to find out for sure. They don't seem to have an answer. Anyone have any suggestions? Thank you!
  3. pushbroom
    pushbroom Road Train Member
    1,788
    7,392
    Sep 1, 2012
    Anytime I have had an Ecm drop timing cal or injector codes, replacing the Ecm has solved the issue.
    Did the ecm get replaced with a new Cat one or an aftermarket? Is the file the correct current Cat file or something else put in there? Ecm powers and grounds load tested and visually checked back to the batteries?
    Shawn2130, A5¢, SAR and 2 others Thank this.
  4. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    trim codes reverting and not loading into the ECM is typically seen with incorrect date and time. Can also on occasion be seen with the ECM losing its timing calibration.
    its a sign the ECM internal battery is failing. If you know someone who can solder circut boards you can replace the battery only instead of whole ECM. its about 10% the cost of a reman ECM
