Active Fault
Discussion in 'Questions From New Drivers' started by TravR1, Jul 23, 2018.
  1. TravR1
    TravR1 Road Train Member
    3,695
    9,759
    Nov 9, 2017
    TX
    Does anyone happen to know what Active Fault EEC (1) means? It started up a while ago. The #### smart idle will not stay on depriving my sleep. There is a yellow engine light and red engine light.
    I am near Chattanooga, no where near any terminal. Anyone know if this is a critical issue?
    Its a freightliner cascadia.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Snoop around the on display menu system, there should be a diagnostic selection. Go into that , it will give you more info.
    If both yellow and red lights are on either it is going to shut down soon or derate you to 5 mph.
    TravR1 Thanks this.
  4. TravR1
    3,695
    9,759
    Nov 9, 2017
    TX
    I tried to do that I am not sure all i was able to get was eec 1. But that red engine light bothers me. I'll call breakdown and see what they say.
  5. BillStep
    BillStep Light Load Member
    195
    238
    Mar 17, 2016
    Does it need a regen?
    TravR1 Thanks this.
  6. TravR1
    3,695
    9,759
    Nov 9, 2017
    TX
    We were going to try that next. I read that with check engine lights on it might not work. My codriver is resetting it with battery switch.
    BillStep Thanks this.
  7. Dave_in_AZ
    422,974
    Sounds like it needs a parked regen. Usually gives you some warning before the DPF just goes belly up.
    BillStep and TravR1 Thank this.
  8. ncmickey
    ncmickey Road Train Member
    3,862
    7,310
    Jun 21, 2013
    Durham NC
    Try the regen. The red engine light means STOP.
  9. Dave_in_AZ
    422,974
    Do you have oil pressure??? DD15's sometimes just drop the pick up tube.
    TravR1 Thanks this.
  10. TravR1
    3,695
    9,759
    Nov 9, 2017
    TX
    The regen worked anyway and all the lights went off. I'll be ######.
    ncmickey, BillStep and Dave_in_AZ Thank this.
  11. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    When it said eec 1 you should have been able to go deeper into that with the menu enter switch for more details.
