add on oil recirculation filter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by generallee, May 5, 2014.
  1. generallee
    generallee Medium Load Member
    512
    441
    Jan 4, 2014
    Can anyone point me in the right direction as to where to get some info on them? Where to buy, cost, benefits of installing one. Are they worth the money? How effective are they? Any info would be great. Thanks.
  3. generallee
    512
    441
    Jan 4, 2014
    34 views and no opinions/suggestions?
    Ok, this is what I've found since I posted this.
    http://www.amsoil.com/shop/by-produ...duty-by-pass-filtration-system/?code=BMK30-EA
    For the cost of these I think it would be well worth the investment just in the money saved by not changing the oil so often not to mention the added protection. I guess I'm surprised more people aren't using them or am I missing something?
    Exiled Thanks this.
  4. Exiled
    Exiled Light Load Member
    181
    29
    Apr 20, 2013
    Very usefull for me thx
  5. Elroythekid
    Elroythekid Road Train Member
    2,620
    5,674
    Sep 9, 2010
    Halifax Nova Scotia
    Spend the money and get a real bypass system that filters down to one micron. OPS Is one that a lot of people use.
    generallee Thanks this.
  6. Kersey
    Kersey Light Load Member
    76
    75
    Feb 13, 2014
    http://www.gulfcoastfilters.com
    I have been looking into the Gulf Coast system. External filter mounted behind the cab holds 2.5 more gallons of oil. A buddy of mine spends about $100 on two filters and a couple of gallons of oil and an oil test every 30k. Gulf Coast does the oil sample an if any problems calls you.
    I have a Cummins ISX and other forums said filtering down to on micron would help the inherent carbon problem these motors are known for.
    Right now only certain TA's are doing the installs. I am having my guy that does my work at home look at ordering one to his shop and having him do the instal my next trip home. But I do know if you get the install with a service at a TA your looking at about a $1000 dollars for the System, install and the service.
  7. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    I believe the bigger spinners are a great adition they need no aditional oil the filter change is cheap it is a piece of paper and 2 "O" rings.
    Years ago most vehickles came with a Luberfiner, filter the 750D had limestone in the bottom to remove the acid in the oil, I believe they used an extra 3 gallons of oil.
    Many engines use to come with factory installed bypass filters, Cat and Cummins, especially
    snowblind and generallee Thank this.
  8. upallnite
    upallnite Light Load Member
    165
    115
    May 15, 2010
    Hempstead,TX
    I run a filtration solutions bypass system. been happy for several years now.
  9. slippez
    slippez Bobtail Member
    22
    4
    Apr 13, 2014
  10. dwmac71
    dwmac71 Light Load Member
    183
    92
    Mar 23, 2008
    Lane,ks
  11. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    Ops1 has a very good system, they package a deal that includes a few lab tests.
