Adding a fuel filter to 3406E
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gafred99, Feb 15, 2017.
  1. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
    I replaced the Do Not Remove cup with a tall Cat filter, truck already has a Davco any fuel delivery issues running both on a 3406E 97 vintage?
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Im assuming your davco has a 7 micron filter if that was the only filter.
    If you want to go back to a cat filter then you need to put a 50 micron in the davco.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    No issues. I assume that if it only had a Davco, it was a 7 or even a 2 micron filter. Run the Cat secondary and up the Davco. You'll get no benefit running the same or larger micron secondary.
    SAR Thanks this.
  5. gafred99
    155
    12
    May 28, 2009
    Tignall
    Davco has a Carquest 86651xe allegedly made by Wix (33651XE) 5 micron
    Secondary is a Cat 1R-0749 2 Micron is what I saw published for this one.
    To restrictive for the pump?
  6. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    You dont need a 5 micron filter in the davco if your running a 2 micron on the engine.
    The davco is there to just get water and big particular out now. Put a 50 mic in the davco. Less restriction that way.
    Youll prob only have to change it once a year like that . If you keep the 5 mic in the davco you will be changing it a lot more often.
    Oxbow, SAR and GrapeApe Thank this.
  7. gafred99
    155
    12
    May 28, 2009
    Tignall
    Ok got it, I purchased a dozen of the 86651xe, was a Carquest going to Advance store closing sale. Was a good deal...
    thanks for help all....
