Adding gauges I don't have
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, Nov 12, 2012.
  1. silver dollar
    silver dollar Medium Load Member
    481
    211
    Jan 31, 2009
    Central North Carolina
    My '02 international with C15 engine does not have a boost gauge or a suspension load gauge. Can you fellas give me tip on how to install both of these. Thanks
  3. Poor boy
    Poor boy Bobtail Member
    49
    43
    Feb 10, 2011
    Kansas
    Both of these are easy to do just simple air line hook ups. Use a bulkhead fitting to go through the firewall ( I think international should have spares in the firewall ). A hole saw will make holes for the gauges in the dash panel if you do not have holes already. Hook your boost gauge in one of the spare fittings on intake on the motor. The suspension load gauge just needs to be hooked into one of your airbag feed lines. This is all very easy just takes a little time to run and feed your airlines through.
    silver dollar Thanks this.
  4. silver dollar
    481
    211
    Jan 31, 2009
    Does it matter which side of the charge air cooler the boost line is attached? (before or aft)
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    There is probably an unused fitting right on the head you can use.
