adding gauges on kenworth
Discussion in 'Ask An Owner Operator' started by pavrom, Sep 27, 2021.
  1. pavrom
    pavrom Road Train Member
    3,215
    7,407
    Apr 29, 2012
    NE illinois
    can anyone assist what's the proper way of adding gauge on 2007 and up kenworth (i think w900 , t800 , t660 same)
    i plan on ordering this type of gauge Gauge Pyrometer Gen3
    to keep the hem look , as well as turbo boost and oil temp
    ...i believe its hooked through ecm , i need to add thermocouple ......
    i am familiar with aftermarket gauges hook up , but not oem
    i would like to keep oem look on my dash
    appreciate any help
  3. CropShop
    CropShop Bobtail Member
    32
    18
    Mar 24, 2020
    We got a pyro gauge from a local diesel shop that installed in the dash with the OEM look and the thermocouple just hooked right up to it. I don't have any more info other that. It is a digital gauge instead of analog.
  4. pavrom
    3,215
    7,407
    Apr 29, 2012
    NE illinois
    ..probably aftermarket
  5. pavrom
    3,215
    7,407
    Apr 29, 2012
    NE illinois
    ...any pics ?
  6. CropShop
    32
    18
    Mar 24, 2020
  7. CropShop
    32
    18
    Mar 24, 2020
    Yes it is some aftermarket. No pics tonight, will see if truck is around anytime soon.
  8. pavrom
    3,215
    7,407
    Apr 29, 2012
    NE illinois
  9. CropShop
    32
    18
    Mar 24, 2020
    Can't help you on getting the factory CAN Bus gauge going. I am thinking that might get info from the cab controller, but not sure. Those gauges are interesting how they work. You can plug them in however you want them on the Daisy chain, and they will still read the same. Also they can be moved from truck to truck with no programming. You would think that they would need programmed, being on the CANBus, but they swap right in. You can't do any more than talk to Big Rig or your KW dealer and see if they could help. It is unusual to get very far with the dealer though.
  10. CropShop
    32
    18
    Mar 24, 2020
    pavrom Thanks this.
