adjusting brakes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by prisoner61786, Jan 26, 2020.
  1. prisoner61786
    prisoner61786 Bobtail Member
    18
    Jun 20, 2011
    im new to working on trucks and learning as I go .while adjusting brakes today i think i made a mistake and loosen the locking nut before i released the brakes. and now the locking nut sprang out and I can not screw it back in place. i would be very grateful if anyone could point me in the right direction to repair
  3. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    Pictures would help.... Not familiar with a "locking nut" on slack adjusters.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Caging bolt ?
    prisoner61786 Thanks this.
  5. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    If you are working on automatic slack adjusters you should not have to adjust them.
    If you release your brakes and give them a few good hard applications, like over 90 PSI, they will adjust themselves.
    If they do not adjust themselves they will need to be replaced.
    It is important to keep them greased.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I second the hard to the floor applications of the service brake vs slack adjusters. You will probably get them good enough until the next mechanic who has training to look them over.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Meritors have what looks similar to the head of a bolt, 3/4". There is a spring and a lock pawl under it. The lock pawl has a flat side and will only go in one way.
    If they are not working sometimes the lock pawl has to be replaced. We normally do not mess with them as well. Just check the travel at every service and maybe snug them up a couple clicks.
    Auto slacks that need constant adjustment should have a professional look at them. Incorrect brake chamber lengths will also cause them to malfunction.
    Cabinover101, jamespmack, SAR and 4 others Thank this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Yes and
    Yes
    Also make sure the chambers are the same.
    I see alot of long and standard stroke chambers on the same axle. Some roadies dont know any better or just throw on what they have it seems.
  9. Michael 247
    Michael 247 Heavy Load Member
    894
    4,689
    Nov 20, 2017
    Dublin Va
    I think there's a small round metal ball under that spring..Be careful not to loose it..
  10. prisoner61786
    18
    Jun 20, 2011
    20200125_132047.jpg this is the locking nut that I was talking about
  11. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    That is the pawl as @BoxCarKidd stated Meritor slack.
    Thread it back in. Pry out the center with a flat blade to release the locking pawl. The 5/16 square on top is the adjuster. You must advance the adjuster tight slight to get the pawl to release from its bite. Then back off.
