Advice needed asap.
Discussion in 'Freightliner Forum' started by Oldironfan, Jan 13, 2018.
  1. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    Columbia glider 12.7 Ddec 4.
    So I was driving along in ky and it seemed my fuel was not getting to engine? But than it stopped after a bit.
    My make stopped working just a few minutes after this. I wiggled brake and clutch pedal, but did not help.
    Than as I went to turn off onto off ramp in Oak grove, KY, my rpms when out of gear were staying at 1500 rpm on its own. I had to turn off truck and restart engine to park.
    Is this a fuse, or sensor, or ECM issue?
    I am going to unhook batteries and see if that helps. Even right now at high idle set at 1000 it keeps going to 1500 on its own? This is not a dpf truck. And it is a manual 10 speed. Here is the last ecm trip report. The ecm did not have much information as it should have had. Seems fishy.
    I also posted this in the tech forum.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Take her off cruise see if you get that engine to settle down. If she cranks to 1500 on it's own, slap the #### hammer once. She should settle down.
    Oldironfan Thanks this.
  4. Oldironfan
    5,776
    5,544
    May 22, 2017
    I took off of idle and tapped hammer but it climbed on its own still to 1500.
  5. Oldironfan
    5,776
    5,544
    May 22, 2017
    I have started engine after battery unhook. And now make a are back ,and idle is holding at 1000. Guess I'll take a go at it.
  6. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Throttle position sensor maybe
  7. Oldironfan
    5,776
    5,544
    May 22, 2017
    It's back to normal right now.
  8. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Collasped return fuel line.
    Oldironfan and Oldironfan Thank this.
  9. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    Sounds like air in the fuel to me also
  10. Oldironfan
    5,776
    5,544
    May 22, 2017
    Has not happened lately. I do believe it's an programming ecm type issue.
