Aerodynamic Wheel Caps
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jayhawker_1012, Apr 3, 2014.
  1. jayhawker_1012
    jayhawker_1012 Light Load Member
    150
    35
    Apr 17, 2012
    There are many companies that have and are making an investment in aerodynamic improvements to their trailers including side skirts, flo below, and trailer tails. Why are drivers not adding aerodynamic wheel caps to at least to their drives to compliment the mpg improvements gained by these trailer improvements?
    TULY007 Thanks this.
  3. Voltrucker
    Voltrucker Medium Load Member
    467
    133
    Sep 24, 2012
    West TN
    Because they look plum stupid!
  4. jayhawker_1012
    150
    35
    Apr 17, 2012
    Ok I will give you that. Still, if they help improve fuel mileage along with the investments being made in trailers why not use them? The only trucks I regularly see with them are Schneiders.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    This is only rumor, I have not seen it myself. I was told from a mechanic for a fleet that tried them and they took them off. He said that they had shortened brake life and more brake problems due to them cutting out all the airflow that helps cool the brakes. Might be an issue if you run some long hills often.
  6. s36ryan
    s36ryan Light Load Member
    80
    18
    Nov 11, 2013
    Buford, GA
    Mesilla Valley has had them on their prostars for years.
  7. jayhawker_1012
    150
    35
    Apr 17, 2012
    I did some research on brake temperature variations with wheel caps. The testing information I have come across shows a 5% temperature increase over wheels without the caps.
  8. jayhawker_1012
    150
    35
    Apr 17, 2012
    Yes. I have seen them as well. Thanks for reminding me. But why would an o/o spend money to put aerodynamics on a trailer they own but not compliment the investment with wheel caps. We know there is fuel savings by using them. Certainly vanity isn't the issue when it comes to chrome?
  9. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    mattbnr Thanks this.
  10. jayhawker_1012
    150
    35
    Apr 17, 2012
    I have looked at those. Have you added any aerodynamics to your trailer or do you pull for a company that uses aerodynamics on theirs?
  11. flood
    4,168
    4,047
    Dec 25, 2010
    the reason i got this set was by fmcas reg's part of your pre trip you much check your hubs for leaks and your lug nut's.... if you can't see thrugh the covers then by the reg's you must take them off everyday..... but with this set you don't have to take them off to check.... also i added their air lines so i can check the psi. without taking the covers off
    can't do anything about the trailer it a company trailer.....
