Air brake issue
Discussion in 'Questions From New Drivers' started by Chebbydriver7195, Mar 30, 2019.
  1. Chebbydriver7195
    Chebbydriver7195 Light Load Member
    113
    121
    Feb 24, 2019
    So after my last incident I have begun doing a very rigid by the book pre trip. Taking 30 minutes on duty every morning to do it right.
    Well today I hooked up to a trailer, did my walk around and a honest pretrip+air brake test. No real issue, minor air loss like 2 psi guage barely moved in 1 minute. Now I've been parked and cant keep air without truck running.
    I KNOW it's in the trailer, but cant find where.It sounds like it's from somewhere on the passenger side near the tandems.
    I've got experience working on equipment but not air brakes.
    Suddenly after 200miles I have an issue out of no where. Anyone got advice on what to look for?
    Very hot load delivers the 1st and I've got 400miles to go.
  3. TripleSix
    133,260
    Do you have a trolley valve? I am assuming that you don’t have an air leak when the red valve is pulled out. Odds are it’s one of your brake chambers on the trailer.
    Suspect Zero and Bean Jr. Thank this.
  4. WesternPlains
    6,366
    57,275
    Sep 1, 2017
    Rapid City, SD
    Look for a TA. Walk inside. Point at trailer. Say: Fix.
    peterd, TankerP, Lumper Humper and 3 others Thank this.
  5. Chebbydriver7195
    113
    121
    Feb 24, 2019
    Yes to the trolley valve. I left the parking brake set and pushed red knob in. Bad air leak. Push yellow knob in and pull red knob out no air leak.
    Trolley valve down =rushing air sound under tandems. Hard to track because of noisy parking lot. There's a boss shop nearby I'll go to in the morning.
  6. Ridgeline
    22,720
    123,238
    It don't matter what the load it, get it fixed or have them replace the trailer.
    Bean Jr., magoo68, Tb0n3 and 1 other person Thank this.
  7. Ironwindow
    Ironwindow Light Load Member
    125
    156
    Mar 1, 2019
    Winston Salem, NC
    Got an air line leaking in the trailer some where. Quiet possibly have an air tank drain valve open.
    Its not a brake chamber or brake hose, they'd only leak when pedal was pressed.
    Maybe a bad relay valve.
    tank4life Thanks this.
  8. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    I'm not advocating you do this, whenever I was in the middle of a delivery and a brake can started leaking, I would remove the airline and stick a dime inbetween the fitting and the line stopping air from going to said can till I could get a new can and fix it. Definitely Old skool.
  9. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    lets see how smart people are. when doing a brake down test. which knob is suppose to pop out first
  10. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    The tractor protection valve. Yellow first. Forget the trailer, it's gone. That pops later.
  11. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    They both pop at the same time.
