Air brake issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Oct 22, 2015.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    Good day all my 96 kw t600 is letting air out the service line when i apply the brakes when i'm bobtailing. At first i thought it was a rear brake booster but turned out to be the service line letting the air out.
  3. lots of character
    lots of character Road Train Member
    1,031
    1,814
    Aug 12, 2015
    Trailer supply valve must be dinked up
  4. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    The valve is also called a tractor protection valve. It will be located along the frame somewhere it depends on make. Not sure were kw puts them. follow service line from gladhand. Both service and supply lines connect to the valve.
    AModelCat and truckerbangin Thank this.
  5. lots of character
    1,031
    1,814
    Aug 12, 2015
  6. AModelCat
    164,495
    Tractor protection valve is done. The valve shuttles over when trailer supply button is pushed in, allowing service air to the trailer. Spool in the valve is probably gummed up and sticking. The valve on my W900A is located inside the left frame rail, next to the transmission.
