Air break issue
Discussion in 'Questions From New Drivers' started by sailfish27, Apr 8, 2021.
  1. sailfish27
    sailfish27 Bobtail Member
    18
    8
    Mar 28, 2021
    When I do a pre-trip on the air breaks, I lose a good amount of air with the service break depressed. Not so much if I lightly apply pressure.
    Mentioned to mechanic and boss to no avail. Not too worried, though maybe I should be? I'm driving a 6 wheel dump, manual transmission and feel safe.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Hold down the brakes ( don’t take a break ) maximum pressure, after the gauges stabilize. Time it for two minutes. If you drop more than six pounds in your tanks then you’re out of service.
  4. Dennixx
    Dennixx Road Train Member
    4,540
    14,592
    Feb 13, 2010
    twin cities
    Even less for a straight job I believe.
  5. AModelCat
    164,481
    4 PSI on a straight truck I believe. 2 PSI for each additional trailer.
    uncleal13 Thanks this.
  6. AModelCat
    164,481
    If its just an initial pressure drop then it stabilizes, completely normal.
    Look at the size of all 6 brake chambers and then look at the size of your primary and secondary reservoirs. A full brake application will easily drop the reservoir pressure 10 or 15 PSI.
  7. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    sailfish, i noticed you using the word break alot . Did something break? If a it was a weld, i would just break out my welder and run a bead. Call it day
    Milr72 Thanks this.
  8. kemosabi49
    10,976
    47,912
    Jan 13, 2013
    SW Arkansas
    Our forum rules do not allow correcting other members spelling or grammar errors. Even in a sarcastic way.
    JolliRoger, 201 and Deere hunter Thank this.
  9. sailfish27
    18
    8
    Mar 28, 2021
    Wow can't get a little slack for a newbie. Long day really tired
    JolliRoger and Deere hunter Thank this.
  10. sailfish27
    18
    8
    Mar 28, 2021
    Got my cdl class b less than a month ago. In school the truck I trained on would hold steady after the initial loss of air. Taught initial drop had to be between 5-15 psi and then no more than 3 psi in one minute.
    The truck I am driving will continuously lose air after the initial loss. Probably more than 10 psi in 30 seconds. In a minute it would probably lose between 20-30 psi.
  11. SoulScream84
    3,456
    26,542
    Mar 21, 2020
    This may sound like a stupid question, but it's a common mistake when testing brakes. Are you pushing the brake completely or just applying pressure, and are you maintaining full pressure throughout the test? I've seen guys who flex their ankle/foot a little throughout the process, and that minor change will keep altering brake pressure thus draining the air more.
