Air break loss while driving
Discussion in 'Ask An Owner Operator' started by Switch707, Feb 7, 2024.
  1. Switch707
    Switch707 Bobtail Member
    12
    4
    Feb 7, 2024
    I have a 2019 International 4300 series box truck. While driving on the highway air brake one gauge is at 120 PSI same as gauge two. Why does air brake 1 gauge loses 4 to 5 PSI on the highway and Purge every 15 minutes? Once it Purge air gauge one goes back to 120psi to match the air gauge two. Air gauge to never moves from 120 until the truck breaks or stops. Some say it's normal because the air dryer is clean out the lines for moisture. Others say that I might need a new air compressor or air regulator or air dryer. Can anyone help me please? Email [email protected]
    77fib77 Thanks this.
  3. Brandt
    Brandt Road Train Member
    4,622
    6,355
    Sep 17, 2012
    You probably have air leak. Air leaks out pressure drops. Air compressor come on fill tank back up and then purges.
    77fib77 and Bean Jr. Thank this.
  4. m16ty
    m16ty Road Train Member
    2,274
    4,964
    Jan 22, 2016
    If you have air ride that will use some air.
    Air dryer should purge every time the compressor kicks out at 120psi. If the dryer is purging a lot it can mean you have a leak and your compressor is cycling a lot or it can just be your dryer needs servicing.
    cke and Bean Jr. Thank this.
  5. OLDSKOOLERnWV
    19,109
    288,946
    Chock the rear wheels on level ground, keep engine off and release the brakes. Walk back to the rear axle and listen for an air leak. May be in the frame rail or a maxi leaking, but you should be able to hear it…
    Ruthless, cke, Oxbow and 2 others Thank this.
  6. Switch707
    12
    4
    Feb 7, 2024
    I think so too, i will service my dryer and see what happens. Thanks
  7. Switch707
    12
    4
    Feb 7, 2024
    I've done that already plus used soap and water and nothing. I dont hear not one leak.
  8. Ridgeline
    22,717
    123,108
    First - TAKE YOUR EMAIL OUT OF THE POST.
    Everything I am posting is based on the accuracy of your first post.
    IF you have posted this right, with low loss and a 15-minute purge cycle, then ... THIS IS NORMAL. NOTHING IS WRONG ... The next quote is why.
    The age of the truck and being an international truck, there will always be system leaks as the truck ages, they use plastic fittings and there is an age factor to them.
    I would worry if you lost 10 psi in less than a few minutes just idling, but 4 to 5 is nothing.
    Yep, that is how it is supposed to work.
  9. abyliks
    abyliks Road Train Member
    4,102
    9,641
    May 2, 2010
    ludlow MA
    Yes, owners neglecting trucks is normal to loose air, My 27 year old truck will go a hour and 20 minutes between purges and holds 60 psi over a day off, start at the governer (where it actually mounts) and start spraying your way back with soap and water, throw a cartridge on or even a whole dryer if it’s one of the cheaper ones first though
  10. 77fib77
    77fib77 Road Train Member
    11,630
    76,613
    Jul 7, 2010
    St Louis
    Every 15 minutes on the highway isn't horrid. It's moving up and down, side to side. Do you have air bag suspension?
  11. Rideandrepair
    17,548
    56,853
    Aug 8, 2015
    For what it’s worth. Air leaks often get worse or first noticed when the outside temperature drops.
