air compressor acting up
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dumbitfown4me, Apr 19, 2020.
  1. Dumbitfown4me
    Dumbitfown4me Bobtail Member
    25
    14
    Aug 20, 2019
    Phoenix
    Hi I have 2016 Cascadia, isx 400, 10 spd, 339k miles. Air compressor has been acting up here and there. what happens is the compressor will turn on and purge in a 45 second cycle, even though the tanks arent low. it does this for a period of time. maybe hours? and and it stops. it will then sit at about 128 psi like before only turning on and purging every 20 to 30 minutes(I do have a small leak that needs to be addressed). last week the blue airline broke and I replaced it and also I got the engine cleaned at a beacon. idk if that's relevant but maybe that's a clue?? What do you think I should do
  3. Zigzag777
    Zigzag777 Medium Load Member
    460
    514
    Mar 25, 2013
    Down Yonder
    If you still have an air leak fix it, and check the condition of all the lines. That would get you a fail in an inspection. You have an air dryer? Make sure it’s working. Or pull into a good
    shop and have them check out the system.
    Too important to ignore.
  4. Dumbitfown4me
    25
    14
    Aug 20, 2019
    Phoenix
    An air leak isn't considered to be a danger by the DOT unless your system is losing 4psi in 60 seconds while holding foot valve at 90 psi application or more. But yes I understand it needs to get fixed and it will when I go to the dealer tomorrow. I'm just trying to understand the seemingly bigger problem at hand before I step into the dealer. Theres a lot of videos online about changing these parts but not a lot of diagnostic material
  5. pushbroom
    pushbroom Road Train Member
    1,788
    7,394
    Sep 1, 2012
    Air drier been serviced recently? New purge valve/desiccant? Line from governor to air compressor been pressure tested for leaks?
    AModelCat, Rideandrepair and Zigzag777 Thank this.
  6. Zigzag777
    460
    514
    Mar 25, 2013
    Down Yonder
    Well, how much did it cost to fix? Just curious.
  7. Rideandrepair
    17,548
    56,856
    Aug 8, 2015
    It’s probably a dryer or govenor problem. Like push broom mentioned, the purge valve, it may be the whole problem.Its old enough, time to change filter and purge valve. Or if cheap enough, depending on which dryer you have, might be easier to just change the whole dryer. That’s what I do, AD9 dryers are cheap though. Don’t know about yours. Price it out.
