Air Compressor running hot
Discussion in 'Freightliner Forum' started by Jerryw3, Jul 29, 2015.
  1. Jerryw3
    Jerryw3 Bobtail Member
    Jul 29, 2015
    Hey I have a 2005 Freightliner w/ Detroit engine, I'm trying to find the cause of a air leak and to see why the air compressor is running HOT - it also burns up that small air pressure hose .within 5 day of replacing it. I have replaced my air compressor 3 times in 3 weeks, the governors, the dryers,
    Please HELP me find out What could be causing the air compressor to run hot
  3. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Is it constantly running and popping off?
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Is coolant able to flow threw head of air/comp.coolant lines crimped or melted closed?
  5. Jerryw3
    Jul 29, 2015
    It was getting hot instantly boiling back up through the reservoir, it was melting the lines every-time.
    $1400, 24 hrs, 4th new air compressor, 2 new hoses and, it ended up being some clogged lines....
    (Helpful Note)The roadside services in Chicago (Lower S. side) is the absolute worst.
    Thank you for the feedback we just just it on the road
    Pray we get that bad boy back to Memphis!! Selling it tomorrow!!!!
    baha Thanks this.
  6. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    clogged lines ? you meant cooling lines ?
