Air conditioner question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perchie15, Jun 4, 2025.
  1. Perchie15
    Perchie15 Light Load Member
    247
    74
    Aug 16, 2021
    I have a 2014 westernstar dd15 and it forsure leaks freon but I use shop air (yes I know we’re not supposed to) but I use it and the gauges haven’t dropped pressure in an hour! So can it be a leak when it only runs? The compressor and everything I thought it’ll leak either way cause it’s under pressure.
  3. Big Road Skateboard
    7,057
    39,971
    May 2, 2021
    High side pressure can get up to 325-350. How much pressure you got? Not enough
    Friend and Bean Jr. Thank this.
  4. Perchie15
    247
    74
    Aug 16, 2021
    125psi it’s the highest it’s letting me go! Then how the heck can I get it higher with shop air?
  5. Big Road Skateboard
    7,057
    39,971
    May 2, 2021
    You can adjust your pressure switch to a higher pressure.
    That's why we always used Nitrogen with a regulator. No moisture, high pressure
  6. Lazer
    Lazer Road Train Member
    1,846
    2,975
    Jan 22, 2017
    I’m lost here. How does the shop air compressor have anything to do with leaking Freon?
    Friend Thanks this.
  7. Big Road Skateboard
    7,057
    39,971
    May 2, 2021
    He's using shop air pressure to try to find his leak, but they're usually cut to 115-125 from the factory.
    That's often not enough pressure to find a leak
    Sirscrapntruckalot Thanks this.
  8. Lazer
    1,846
    2,975
    Jan 22, 2017
    I have never heard of anyone pressurizing an A/C system with an air compressor, would that raw air contaminate the system?
  9. Big Road Skateboard
    7,057
    39,971
    May 2, 2021
    Definitely gonna put a bunch of moisture in it. It'll need a new dryer.
    beastr123 and Sirscrapntruckalot Thank this.
  10. wore out
    wore out Numbered Classic
    17,244
    213,601
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Yes shop air will put moisture in the lines. A new drier is a must. In my opinion anytime you have one open it’s best to do a drier and vacuum it. Moisture boils in a vacuum at like 70 degrees that’s the whole purpose of pulling a vacuum.
    Friend and Sirscrapntruckalot Thank this.
  11. Perchie15
    247
    74
    Aug 16, 2021
    On the truck itself how do I go about that? It has the TVC valve or whichever it’s called I don’t see anywhere that’s adjustable
