Air horns
Discussion in 'Ask An Owner Operator' started by Hotshot2trucker, Aug 18, 2020.
  1. Hotshot2trucker
    Hotshot2trucker Bobtail Member
    26
    4
    Jun 8, 2018
    Anyone ever convert stock air horns to train air horns ? I mean , still have stock horns on your truck but get some train horns and swap the parts that make it louder and sound like a train
  3. fishonron
    fishonron Medium Load Member
    647
    1,661
    Jul 25, 2017
    North Central Kansas
    Why would you want to do that?
    In many cases blasting the standard air hair horn is not legal.
    Speed_Drums Thanks this.
  4. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    factory air horns blow dog poop..Mostly cause its under the drivers feet area on many of the new areo body styles..
  5. Hotshot2trucker
    26
    4
    Jun 8, 2018
    Well I have a 2013 Pete 388 with 268" WB 70" stand up sleeper, 550hp 18 speed Eaton
    feldsforever Thanks this.
  6. 201
    201 Road Train Member
    12,769
    26,263
    Apr 16, 2014
    high plains colorado
    Need a bigger air compressor,,,You'll blow them horns once and your brake buttons will pop out.:eek:
    Big_D409 Thanks this.
  7. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    It’s not that simple. You have to increase the size of the valve and feed line. If you feed a train horn with factory lines you won’t be happy.
    Dino soar Thanks this.
  8. SmallPackage
    5,777
    18,543
    Dec 20, 2019
    Marion Texas
    Like I mentioned in another thread yesterday about this. DO NOT replace a factory air horn or city horn with train horns. Add them “hidden” as a seperate accessory on a seperate switch or valve and on their own tank. They are considered illegal to most law enforcement. If they are activated by the oe horn lanyard pull or the button on the steering wheel and you hit them during an inpection you may have to remove them and get a ticket for inoperable horns.
    I love train horns and have them on all my trucks mounted between the frame rails and on seperate switches isolated from the rest of the brake system and can be disabled at the turn of a shutoff ball valve if need be.
    drive-away2020, Dino soar and 062 Thank this.
