Air impact
Discussion in 'Ask An Owner Operator' started by Spyro2112, Sep 19, 2021.
  1. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    How many pounds is big enough for lug removal at 500 torque with a air impact
  3. AModelCat
    164,498
    Rust/corrosion on the studs play a big part in breakout torque. I've got a 1/2" air impact that'll take off most wheels. Its rated at 1,200 ft-lbs. My 3/4" will put out around 1,800 ft-lbs. Haven't had a wheel it wouldn't take off.
    Advantage of the bigger drive sizes is they hit harder. The smaller guns hit faster but that's no replacement for the heavy initial hit to get it moving.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Putting them back on just snug it up with the impact then use the torque wrench. The bigger guns will stretch the threads
  5. abyliks
    abyliks Road Train Member
    4,102
    9,641
    May 2, 2010
    ludlow MA
    Milwaukee battery gun
    shatteredsquare and Rideandrepair Thank this.
  6. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I keep one of this in my truck, no need for air impact.
  7. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    Used my 1/2 inch Milwaukee last time I fixed a tire. Loosened no problem.
    D.Tibbitt, TallJoe and Rideandrepair Thank this.
  8. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    If they're only tightened to 500 then you could easily get away with a heavy duty 1/2" impact but 90 percent of the time they are put on way too tight. Also, if they've been on there a while the rust makes them incredibly difficult to remove. You'll have to add heat or a good 1" impact...sometimes both!
    TallJoe and Bean Jr. Thank this.
  9. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Forget air. 33 mm socket and pulls em off faster than the air wrenches the tire crews carry.
    1250 backing, 780 forward
    Tested this weekend on my sitting truck, took about 2 seconds hitting before pulling hardest one off
    Cost 300 tool only, have a ton of batteries already
    My 1/2 inch is rated to 750 backing but wont pull off a truck lug.
  10. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    No need for air impact. 3/4 M18 Milwaukee will do what you need.
  11. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    That thing is sweet! No issues with the short anvil getting past the hub on drive wheels?
    msh and God prefers Diesels Thank this.
