Air leak- any help?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 13letter, Dec 19, 2008.
  1. 13letter
    13letter Light Load Member
    109
    16
    Oct 19, 2008
    Fulton, IL
    Please help.... Pulling hair out! Losing air on the secondary side (secondary gauge), only when engine is running. Park knobs in or out, doesn't matter. Sitting in shop looking for a leak. Only losing air when engine running, no air loss when engine off. And can't hear a leak when its running. Been sprayin soapy water around everywhere too. No luck yet. Just replaced the governor and rebuilt the unloader valves on the compressor in the process of elimination.
    Anyone had a similar problem? Appreciate any help! Thanks
  3. Peanut Butter
    Peanut Butter Road Train Member
    1,343
    419
    Nov 24, 2007
    PO Dunk Idaho
    Check the air valve that operates your air bags on the back of the truck, that can go bad and dumps air pretty quick, also check all air tanks valves that you drain the tanks with sometimes someone will open those a crack being a jerk. other wise check all fittings and air brake cans.
  4. Bigstretch
    Bigstretch Light Load Member
    161
    30
    Jun 14, 2008
    NW IL
    PB, both of those could, and most likely would, leak with the truck off as well.
    Does the leak stop with the air compressor engaged, or disengaged, with the engine running?
  5. 13letter
    109
    16
    Oct 19, 2008
    Fulton, IL
    This thing leaks down, compressor kicks in, then purges every 4 minutes. No leak down when not running. All usual leak suspects have been eliminated. Can see pressure begin to drop shortly after drier purges you can see the gauge start to slowly drop. Doesnt seem to drop faster during drier regeneration, or in seconds immediately following purge.
  6. AgLaw
    AgLaw Light Load Member
    61
    34
    Jun 27, 2008
    Wharton, Texas
    You say it only leaks with the engine running; however, I must as if the leak can be observed with the ignition on/engine off? If so, I would look at the engine fan clutch, solenoid, & plumbing as a possible cause. Could also have something to do with the A/C system--some trucks use electric-over-air controls there also. Can't think of anything else on the secondary side--other than steer axle ABS valves--that would have any connection with the "key switch". What make, model, and year of truck?
  7. 13letter
    109
    16
    Oct 19, 2008
    Fulton, IL
    O ya, checked also w/ key on engine of. No pressure loss.
    Thanks all! Anyone know how the secondary side is plumbed? What operates off it? Where is secondary gauge plumbed into?
  8. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    check your spitter on your air dryer. start your truck up let it run till your dryer pops off then listen or reach under it and feel if its still leaking.
    Another way to check is to just bypass the air dryer altogether.
  9. 13letter
    109
    16
    Oct 19, 2008
    Fulton, IL
    Was under the truck with it running a couple times when it purged. Didnt seem to leak after purge. Probably will try it with drier bypassed too. Thanks
  10. cat from the valley
    cat from the valley Medium Load Member
    469
    32
    Dec 8, 2008
    jamaica
    If its only when the engine is started it must be fan related, bend the hose to the fan hub and see
  11. Les2
    5,150
    2,288
    Jul 25, 2008
    If you have a manual switch for the fan just turn it on. You'll hear it if its leaking. If not it should only leak when the fan is running so you wouldn't notice the air loss all the time.
