Air leak only when engine running
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Feb 7, 2022.
  1. insanityeight
    insanityeight Light Load Member
    291
    113
    Jul 26, 2013
    birmingham al
    2014 t680 will hold air over night, usually dropping to around 40-50 psi. Have replaced numerous fittings to get to this point. With engine idling or running down road it will repeatedly drop to 105 kick in pressure every 6 minutes roughly. Im completely stumped.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Does it do that running with the parking brake set?
  4. Concorde
    Concorde Road Train Member
    5,458
    19,225
    Jun 29, 2016
    West Melbourne Florida
    I had a 14 t-680 and was constantly chasing leaks..plastic push fittings.
    To me it sounds like something on the accessory side. Your accessory air tank is located behind your driver side step.
    Remove the 4 bolts and check the fittings..right side of the tank. Soap and water in a spray bottle.
    insanityeight Thanks this.
  5. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    Yes. Just sitting in my yard and also driving as well….. anytime the truck is running regardless of whether its rolling or not.
  6. Hammer166
    7,599
    27,751
    Aug 18, 2007
    ~8600+' and loving it!
    Fan clutch maybe? Turn on the fan see if it still does it.
    AModelCat and insanityeight Thank this.
  7. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    Didnt think of that. Ill try thanks
    Hammer166 Thanks this.
