Air leak question
Discussion in 'Experienced Truckers' Advice' started by NOAH2K, Jan 16, 2026.
  1. NOAH2K
    NOAH2K Bobtail Member
    14
    21
    Feb 28, 2025
    Princeton, Texas
    I have a 2023 freightliner cascadia, and anytime I'm in cold weather, the secondary air tank will lose pressure, while the primary stays full. Mechanics already looked at it and couldn't find any leaks. Air tanks are automatically self drain. Anyone experience this before or know the cause?
  3. Banker
    Banker Road Train Member
    4,506
    14,557
    Aug 19, 2012
    Get you a spray bottle of soapy water and spray connections until you see bubbles while it’s cold. Maybe one of your quick connect fittings.
    Lonesome and tscottme Thank this.
  4. Ridgeline
    22,720
    123,213
    What did the mechanic do? Waive a divining rod over the tanks and didn't get any movement?
    I would think they would take Banker's advice and use a spray bottle on the most common connections.
  5. ESAFO
    ESAFO Light Load Member
    144
    346
    Jan 2, 2022
    Hubbard, Oh
    If it was snow/slush covered when he "looked it over", pretty good chance the walk around could not duplicate issue.
    Meaning not a chance in hell he was crawling underneath it to check fittings/connections.
    I had same issue couple of yrs ago & found out it was my seat air line fitting.
    Couldn't hear it but sure enough slow leak to drain out every night.
    NOAH2K Thanks this.
  6. D.Tibbitt
    156,993
    How much is it draining and over what time period? If it only happens in cold weather its probably a quick connect fitting somewhere. If its only the secondary tank, check your airbag fittings, air ride seat fittings, anything that runs off the secondary tank.. soap and water. Id bet money its a bad quick connect
  7. Moosetek13
    Moosetek13 Road Train Member
    14,975
    19,013
    Nov 1, 2010
    Burnsville, MN
    Probably first pulled it in to the shop and let it warm up a bit before getting to work on it.
    Was that the mistake?
  8. NOAH2K
    14
    21
    Feb 28, 2025
    Princeton, Texas
    As of this morning, I can hear the air Governor cut off every few minutes. Im going back to home terminal for home time and will put in a request to get it fixed
    Lonesome Thanks this.
  9. upnorthwpg
    upnorthwpg Road Train Member
    1,829
    2,790
    Sep 23, 2011
    You sure you’re not hearing the air dryer? Mine freezes up and sounds like a leak but it’s not. Just the cartridge frozen.
    NOAH2K Thanks this.
  10. upnorthwpg
    1,829
    2,790
    Sep 23, 2011
    The one way check valve may be iced up as well. See if they can pull the line off the compressor and pour air brake antifreeze in there.
    NOAH2K Thanks this.
  11. NOAH2K
    14
    21
    Feb 28, 2025
    Princeton, Texas
    No its the noise that you hear when the air tanks reach max pressure, like a sneeze
