Air leaking when cold
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ciufero, Jan 31, 2019.
  1. Ciufero
    Ciufero Bobtail Member
    19
    Dec 29, 2018
    Air is leaking when cold ( around 15 min after start up), when its warmed up everything seems normal. Anything to look for?
    Rideandrepair Thanks this.
  3. Cattleman84
    Cattleman84 Road Train Member
    10,002
    71,354
    Nov 1, 2017
    The Sticks, Idaho
    Frozen pressure relief valve?
  4. Rideandrepair
    17,519
    56,765
    Aug 8, 2015
    I’ve had that happen a few times. Leaks show up when it’s cold outside. Usually a pinhole in pancake on brake chamber. Soon to fail fully.
  5. Cattleman84
    10,002
    71,354
    Nov 1, 2017
    The Sticks, Idaho
    Not fun... Had that happen last week.
    InTooDeep and Rideandrepair Thank this.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    Feel for air blowing out the bottom of the dryer. Next test the governor.
    Wannabe tech and Rideandrepair Thank this.
  7. Ciufero
    19
    Dec 29, 2018
    it was johnson bar valve (behind the dash) leaking when cold
  8. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Invite a young person who can actually hear and have him or her help you find where it is leaking from.
    This is what I do.
    BoxCarKidd Thanks this.
  9. BigRedSA
    BigRedSA Bobtail Member
    15
    13
    Mar 24, 2019
    USA
    Had to call roadside for a driver who froze his brakes up in the mountains, roadside guy put coolant in the trailer airline by funnel and pumped rhe trailer valve a good bit and it did the trick
  10. JohnC123
    JohnC123 Light Load Member
    135
    66
    Jan 25, 2018
    Just a thought, secondary tank, old air bags (dry-rotted areas until rolled out full).
