Air loss!
Discussion in 'Freightliner Forum' started by Bob.g, Oct 22, 2016.
  1. Bob.g
    Bob.g Light Load Member
    74
    23
    Sep 28, 2015
    Could someone explain how after 24h of being parked I found that The gague of the primary tank at 80 psi the gague from the secondary air tank at 0 psi and the cab airbags were empty. I just changed the levelling valve due to a leak and I was told that could be the reason but i my didn't do the trick same problem
  3. Bwbibb
    Bwbibb Light Load Member
    119
    111
    Jan 4, 2016
    Could be alot of things. Leak on the transmission. Just had a purge valve leak fixed, you had to be laying on the ground next to it to hear it. So your going to look around and listen for it. Get a spray bottle mix water and dish soap and spray on connections.
    Bob.g Thanks this.
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Yup, could be anything. Spray away and listen.
    Bob.g Thanks this.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Look for a air blower T fitting under drivers seat, ck. the lower part of cab air bags where they flex for leaks?
    Bob.g Thanks this.
  6. Bob.g
    74
    23
    Sep 28, 2015
    Thanks man ill get it checked out. I had another valve at the transmission changed recently too because it was leaking
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Any time you lost air, check your air compressor first before proceeding down the network of air lines etc. If the compressor has quit working, that is your problem right there. If not? Like others said, soap and water and follow the lines until the leak reveals itself.
