Air pressure issues
Discussion in 'Freightliner Forum' started by STap, Sep 12, 2013.
  1. STap
    STap Light Load Member
    123
    21
    Aug 24, 2012
    Me and the hubby are company drivers. We don't own our truck but I like to try to learn things about the truck. So we pick up regular 53' trailers, dry bed. Nothing special. Most of the trailers are new-ish and don't give us too much of a problem. The last few trips we have gotten trailers that were obviously older. PTI all checked out fine. But as we drive the air pressure increases really high. Both needles pointing to 6 o'clock on the gauge. Our truck releases the excess air but it climbs right back up within a second or two. So we are releasing air pretty constantly. When we don't have the trailer attached its fine. When we have a newer trailer it's fine.
    We are only going to have this trailer for another hour or so. What is it about the older trailers that might make this happen?? Oh, we have a 2012 cascadia.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    UR air gov. on air comp. is sticking, replace.
  4. dilligas
    dilligas Light Load Member
    83
    42
    Sep 3, 2013
    Needles pointing to "6 o'clock" means nothing>what is the psi reading on the guage?
    If this constant cycling is going on it may be an internal leak in a brake chamber on a trailer that you don't hear. Have you parked the truck/trailer in a quiet area with all of the brakes released and listened carefully for air movement?
  5. STap
    123
    21
    Aug 24, 2012
    Sorry about that... The gauge reads about 175. The gauge numbers stop at 150. And no, haven't parked it in a real quite area. But that is definitely something for me to listen for. I'm still new at all this and I know the standard PTI doesn't necessarily cover EVERYTHING that can happen in the road.
    Any input is greatly appreciated.
  6. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    stop driving IT the weakest air line willpop off U will B sitting on side of road. stop at any T,stop its a 2 simple fix, ck UR mant. desk
    STap Thanks this.
  7. dilligas
    83
    42
    Sep 3, 2013
    175 psi>are you sure? Most governors kick out @ 120 psi.
  8. STap
    123
    21
    Aug 24, 2012
    Let's say the gauges are a clock face. 150 is at about the 5. The needle is pointing straight down at about the 6. With the way the numbers are spaced on the dial I would say 175 is accurate. The governor does kick on from time to time before that just to maintain a good 110-120. Now it is kicking on and releasing air for Bout 2-3 seconds. Then does it again in about 10-15 seconds later.
  9. STap
    123
    21
    Aug 24, 2012
    Never mind. Truck is doing the same without trailer. Shop time for us. Booger!!
  10. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Air compressor governor is shot
  11. STap
    123
    21
    Aug 24, 2012
    Yep, that's what I thought. Is this a common enough problem that freightliners and or TAs will have that part handy???
