Good day got a Fld120 that keeps popping air pressure switches(air leaking out switch)behind steering column. They last about a month then it’s back to leaking. Any idea as to why they keep going bad?
Air pressure switch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by truckerbangin, Feb 3, 2022.
How many of them start leaking, cause there are several?
What does this switch do? I owned an fld for 15 years (until 2015) and don't know that there was a switch-at least I never had one go bad. Is it for tilt/telescopic adjustments?
Is the govenor set Cut out set right?
BoxCarKidd Thanks this. -
There is a socket made for them. If you to pull hard on them with channel locks of something you can distort the housing, even break the plastic.Rideandrepair Thanks this.
