air problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Diesel Dan 92, Jul 25, 2020.
  1. Diesel Dan 92
    Diesel Dan 92 Light Load Member
    137
    50
    Nov 27, 2015
    2006 T800 with 2005 C15MXS motor.
    Under acceleration the compressor safety valve sometimes will pop off.
    Running the truck in the shop the air builds to 125 and purges, It only does it at high rpm / load
    I'm stumped.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,538
    6,611
    Aug 26, 2014
    I would thank it hard to know it is the compressor safety valve while driving down the road. You mentioned the air pressure in the shop. What is the air pressure on the gauges when you hear a pop off on the road?
    Rideandrepair and Diesel Dan 92 Thank this.
  4. Diesel Dan 92
    137
    50
    Nov 27, 2015
    It is the safety valve, for sure.
    Pressure on the the gauges is usually 110-125
    I've run shop are through the main discharge line and it doesn't seem restricted at all.
  5. AModelCat
    163,411
    Are you sure its the compressor valve popping off?
    I don't know about the MXS for sure but some engines/trucks used a similar valve post-turbo as a safety valve to prevent overboost.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    That safety valve does go bad, sounds like a machine gun. I remember replacing couple on ACERT engines.
    Rideandrepair Thanks this.
  7. BoxCarKidd
    4,538
    6,611
    Aug 26, 2014
    That did not answer the question of what are the air pressure gauges reading while a relief valve is popping off.
  8. Diesel Dan 92
    137
    50
    Nov 27, 2015
    yes it did, the valve pops at those pressures.
    Rideandrepair and BoxCarKidd Thank this.
  9. Diesel Dan 92
    137
    50
    Nov 27, 2015
    yes I am, ive already had to replace one because it wore out from popping off and wouldn’t hold.
  10. 062
    062 Road Train Member
    6,311
    33,935
    Oct 20, 2013
    What psi are you replacing it with?
  11. Diesel Dan 92
    137
    50
    Nov 27, 2015
    It was 150 or 200 I’d have to double check
