Air ride cab
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brookshire36, Feb 28, 2021.
  1. Brookshire36
    Brookshire36 Bobtail Member
    18
    Apr 28, 2020
    Once again problem with the 2002 ford sterling, the problem is I noticed the cab sitting down alot on the backside of cab, I noticed two brackets on each side of cab mounted to the frame and cab is sitting down on them, now my question is are there supposed to be air bags that go from brackets to cab or bushings, its a lt9513 model, and if air bags where is the air lines located, have notice the previous owner had disconnected and removed a lot of stuff for some reason any diagram where air lines should be and come from thanks in advanced
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    With the last 6 of the vin a Freightliner dealer should be able to tell you how it came. Other things could have been done.
    Rideandrepair Thanks this.
